Question about HP OfficeJet 6210 All-In-One InkJet Printer
Keeps giving instruction remove and check color cartridge
Keeps giving the instruction "remove and check color cartridge". I do this and instruction continues. I have turned the machine off as well as unplug the machine.
  • Anonymous Mar 01, 2009
    I have the black cartridege issue same as above put doing what you stated didn't work. Anything else to try
    Problem Solver:
  • 14 Answers
OK this issue needs to be resolved in a different manner take all the ink cartriges and after they are removed unplug the power cable from the back of the printer and after that press and hold the # and 6 button at the same time ,while holding it plug in the power cable back in the printer then as it turns back on release the buttons the printer will perform a reset within itself ,it is called a semi-full reset after it is done insert the cartridges back into the printer it will align the cartridges after that the issue should be resolved if not then there is some problem in the ink cartriges and replace them still if it does not work notify me and do let me know this issue gets resolved or not.....
Posted on Feb 23, 2009
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
Remove and Check Color Cartridge keeps appearing. I have changed color cartridge and message still appears.
is a non-original or defect color cartridge. ask for change cartridge to original. If still continues, ask for a new printer the cartridge bruned your printer board.
Jul 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Just bought this at a local office depot. tried setting it up, but it keeps giving the carriage jam error message even though there was no paper jam. The paper is not feeding either
Did you remove all the transport locks mentioned in your manual or quick setup poster? There may be quite many of them, beginning with a sheet of paper in the drum cartridges, to some plastic pieces here and there, to plastic seal pulls in the toner cartridges.
Do consult the instructions, you may have missed something.
Nov 26, 2009 | HP LaserJet 8500 Color Printer
Error "remove and check color cartridge" after cartridge was refilled.
try cleaning the contacts opd the color cartridge
with a wet towel
if the problem is not solve return the cartridge in the shop you get it and ask them to replace it
Apr 13, 2009 | HP Photosmart 2610 All-In-One InkJet...
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
I am using the workcentre 4150 and the printer keeps giving me an error saying. "toner supply failed, remove seal tape from toner cartridge and reinstall" I can't find any tape on toner...
The seal tape might be inside the cartridge, attached to a pull-tab.
I am only specifically familiar with the HP toner cartridges, which have a colored plastic pull-tab attached to the tape which seals the toner drum during transit. You have to pull on the tab which in turns yanks the sealing tape out after it.
Each HP cartridge has a small instruction sheet included which shows the location of the pull-tab. Perhaps your Xerox cartridge came with a similar diagram sheet?
Apr 03, 2008 | Office Equipment & Supplies
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
Black and color cartridges
have one black and one color cartridge in my printer but it keeps giving me an error message:
Oct 14, 2007 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
