Question about Bose Acoustimass 15 System
I have an acousticmass 15, and the subwoofer emits louder hummm
I have an acousticmass 15, and the subwoofer emit a hummmm even when it is totally disconnect from receiver and speakers, The Bass control of the module appear to be a little loose when I twist the control the hummm dissapear, maybe I need to change the bass control but I don't know the type of control. I remove the cover and everithing looks well no disconnections or bad soldered joins apparently.
  • 2 more comments
  • afibanez Feb 18, 2009
    Sorry for my bad english and my ignorance... What is a feedback issue??
    Ok. Thx. Yes I have checked all this issues, I isolated the subwoofer only with the energy power and when I turned on the hummmm beging very louder, then I twist the bass control and hummm dissapear and the subwoofer work fine until the bass control moves itself again (loose), maybe can work fine days even weeks but suddenly the hummmm begins again.
    THX
  • Ryan Lee
    Ryan Lee May 11, 2010
    feedback issues would be anything electronic near the subwoofer that could be emitting the humm you hear. typically trhis involves a audio input method of sorts i will use a microphone as an example. when plugged in and powered on if the microphone is to close to a speaker the sound picked up from the microphone travels through the speaker and emits feedback
  • Ryan Lee
    have you checked any feedback issues?
  • 77 Answers
Greetings afibanez,
so far from the information gathered from you, it sounds as if the control knob mechanism in the unit itself is going out. the fact that it adjust on its own, and the humm indicated that the position sensor in the control knob is malfunctioning. If at all possible visit the manufacture's website and there should be a search bar once you have searched for and found your product, there will or should be a link to help you purchase parts and accessories for the unit. I hope that i have been helpful and this fixes your problem. any diagrams or instructions can be found on the manufacture's website. if you are still unable to complete/fix this problem with the information available or that i have provided let me know and we can take further action at that time. but my main suggestion is to replace the internal working component of the control knob.
Thank you
Ryan
Posted on Feb 18, 2009
I have the accoustimas 15 surround sound. Even when not in use the subwoofer emits a constant thump. It's very low but irritating. What is causing this?
That would be an electrical fault. Possibly an Electrolytic Capacitor that is leaking voltage into the audio circuit. Or a faulty semi-conductor.
Aug 25, 2015 | Audio Players & Recorders
Advent subwoofer
emits a steady sound means that their is some miss connection in the in put
May 23, 2014 | Audio Players & Recorders
Westinghouse 662 oven doesn't totally turn off,
We have had the same issue, it drove me crazy.... Ours has just stopped working altogether now.
Sep 13, 2011 | Ovens
Sometimes there is a very annoying buzzing noise coming from the speakers. Why is that? Can it have something to do with the earth? I have grounded the speakers to an iron stick outside the house.
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Dec 17, 2010 | M-Audio BX5a Speaker
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
Subwoofer with screech and static
This sounds like the output stage of the subwoofer amp has failed -- needs service...
Charlie
Aug 22, 2009 | Definitive ProSub 1000 Subwoofer Speaker
My Polk PSW 303 subwoofer emits a hum when plugged in and powered off. When the unit is turned on the hum gets louder. At this point the unit is useless. Does anyone know what could be causing this?
Hiya sounds alot like there is a power supply issue with the unit that will require repair for it to be doing off or on. Probably wont be to expensive, request a quote first to make sure viable.
Best of luck
Jul 16, 2009 | Polk Audio PSW-303 Subwoofer
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 15 System Logo
443 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
