Question about Sony Video Game Consoles & Games
Bluetooth headset wont pair to pc
My sony ps3 bluetooth headset will not pair to my pc, although it pairs to my ps3. please help!
I fixed this problem by enter "0000" (four Zeros) as the passkey, it accepted it and it didnt ask me to enter the passkey on the remote device ie the headset ,which is handy as it doesnt have any number keys ;)
it then added the device and it stayed on teh "added devices" list!
hope this helps
Posted on Mar 10, 2009
How do i program my ps3 bluetooth headset?
You can pair the headset in two ways:
  • Automatic mode (using the supplied USB cable) - Enables the headset's advanced features for the PS3. Using automatic mode, you can pair the headset with any PS3, but only the most recently paired PS3 will be saved in the headset's list of paired devices.
  • Bluetooth discovery mode - Sets up the headset as a standard Bluetooth headset. By using Bluetooth discovery mode you can pair the headset with many other Bluetooth devices.
Jul 22, 2014 | Subsonic PS3 Bluetooth Headset Camo
How to use bluetooth
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
I am unable to sync my Mad Catz bluetooth to my PS3 and I can't find my bluetooth manual. How do I sync up?
Please see the sync details below:
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Jan 28, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Bluetooth headset is paired, but will not connect
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.....
Jan 18, 2010 | Sony PlayStation 3 40GB System
Ps3 at v3.15, sony headset paired but cannot get speaker on tv
Go to the Audio Settings above the Bluetooth setting and change the Audio output to "wireless headset"...
Jan 10, 2010 | Sony Bluetooth Wireless Headset for...
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
Hope this helped.
Nov 18, 2009 | Mad Catz Bluetooth Headset for PS3
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Pairing mode for headset with PS3
On your PS3 XMB menu. Go to settings. Scroll down to accesories. Then click on manage bluetooth devices. There you will find the autodetect for the bluetooth headset. While the bluetooth headset is off, press and hold th on button until the LED stays on. The quickly use the PS3 to detect the blue tooth. It will ask for a pin to pair the units up. The pin is four zero's.
Jan 09, 2009 | Ubi Soft Entertainment Tom Clancy''s...
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Video Game Consoles & Games Logo
475 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
