In our TLA-04641C Suddenly Thurs. Feb. 12, the color was messed up. Nothing we have tried has fixed it. There had been a power outage during the night, but we have had many of these, and this did not happen before. Any help would be appreciated. Thanks! Leon
  • Leon Green Feb 20, 2009
    Nope. So we have contacted our cable company. They say their technician should be able to fix it. Thanks for trying.
  • 19,396 Answers
The power surge may have damaged the convergence circuits.
Try first unplugging the TV for one hour os oso, if this does not fix the problem , then you need a technician to fix the convergence, one of the convergence ICs must be replaced.
Posted on Feb 18, 2009
    Brigadier General:
  • 3,614 Answers
Check all connections. unplug the tv for a while. plug it into a different power outlet
  • micromaster
    micromaster Feb 18, 2009
    ALSO:
    TEST THE UNIT USING A DVD PLAYER.
    LET ME KNOW
I have a poloride tv and it had colored vertical lines on it. Now the power button is blinking on and off with no pic. What part would I need to fix it.
Write in detail about the power LED blinking because it is blinking codes which reflect the problem/fault of the TV. It will be straight blinking in a sequence and a small break and again sequence of blinking li 5 blinks and break then 5 blinks and break and so on. Note these numbers of blinks, it will decode the error.
If you feel you are qualified to make the repair the service manual can be downloaded from the below websites for free. The service manual will help you diagnose and make the beeded repairs. This model is known for having issues wuth their power supplies failing. Since the problem was likely caused by a voltage spike be sure to check the diodes in the power supply:
http://static.highspeedbackbone.net/pdf/polaroid_tla04011c_manual.pdf
https://elektrotanya.com/polaroid_tla-04641c_4641-tlxb_model-2007_sm.pdf/download.html
https://www.mediafire.com/?dd3d4iwmm8yoa
http://www.mediafire.com/file/udejwknqhmw/TLA-04641C.pdf
May 22, 2017 | Televison & Video
Need an owner manual for TLA D4641C
Thought that was going to be easy but Polaroid no longer have the manuals available for download on their site. Typical.
Anyway, here's a direct link to download your user manual (free):
http://www.hdtvreview.com/pdf/polaroid-tla-04641c-manual.pdf
Click the link, PDF will open in a new window. From there you can view, save and print. Please note your model number is actually TLA-04641C.
Please rate my solution if you find this helpful. Thanks.
Oct 16, 2010 | Polaroid Televison & Video
I have a 46'' Polaroid HDTV model TLA-04641C
It hasn't been 'unplugged' until you have let it stay that way overnight. There are components that need to discharge and that can take hours. You wrote 'standard sounds;' did this mean audio or something else?
If you have normal audio but no identifiable video, then the backlight or the inverter for the backlight has failed.
If audio is present, try looking at the screen from several angels to see if you can identify some ghost-like video. If so, then the above suspicion is pretty much confirmed.
I hate that the modern sets seem so prone to failure, it isn't a good trade-off for the increase in quality of the results. Most of these are not poor engineering but the effort to build them with the cheapest possible parts inside, often only saving a few dollars, but ruining their reputation.
Mar 10, 2010 | Televison & Video
Tla-04641c wont power standby light comes on and the relay clicks but nothing with the power button like im not even pushing it. opened it and pulled the power supply...no capacitors looked bad though i...
Hey listen bulldog, I am just having the same problem! Exact same thing, standy led on, power supply and boards seem like new, but tv doesnt power up! I read a schematic at http://www.polaroidsupport.com/polaroid/docs/TLA-04011C_TLXB-4011_TLXB-4241_ServiceManual_20070613.pdf and if you follow it through it states, to change the control box!! I have fair confidence that I can replace the control box because I have experience in soldering and have built my own computers before as also swapping major components in laptops as well! So I am willing to take the risk to fix this but heres the problem!! I dont know where or what the control box is or where to go to buy a new one! POLAROID customer service is aweful, unless you know the manufacturing plant and can go there, they wont be much help! I hope this info helps you, if you got the problem fixed can you tell me what you did or where I can look to get my issue resolved! Need anything else just post here!
Feb 12, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Unable to program remote on my TLA-04641C.Can't find the code
i have a book with the codes what is the product and name
Dec 14, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Tla-04641c won't turn on
my tla-04641c stoped taking commands the day after using it with my laptop and was stuck on so i unplugged it and now it wont turn on when i plug it in the red light comes on and i hear the relay click button nothing happens when i push the on button. any suggestions? i pulled the power board and nothing "looked blown"
Aug 23, 2009 | Televison & Video
POLAROID TLA 04641C AFTER VGA PLUG TV WON'T WORK
i am having the same problem.. did u ever got it fixed?
May 10, 2009 | Panasonic Televison & Video
Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04011C LCD TV remote codes
I have the TLA-04011c and have yet to find a code. Out of curiosity, have yall? thanks
Dec 21, 2007 | Samsung SyncMaster 17 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
