Question about Kenmore Elite 45986 Front Load Washer
Drum disconected from washer
The drum of my washing machine disconnected from the unit. It dropped about and inch and is not longer connected to anything. How can this be fixed. I can not even figure out how to remove the drum to see why it is diconnected.
  • HABIBI4ALL Feb 23, 2009
    NO MANUAL AVAILABLE....
    i have an Ariston washing machine model margheritta 2000 AB43 for which, I dont have manual to understand its functions. Please provide me the link or manual/guide. Thanks.
  • 5,911 Answers
The wash tub is suspended by two large support springs from the top and 2 to 4 shocks (depending on model) from the bottom. It sounds like one or both of your upper support springs may have come loose for some reason. You will need to remove the top panel of the washer by removing the three screws that hold it in place in the rear. With the screws removed, the panel will slide back, then off. You should be able to see the support springs easily at this point. There is one connected to the drum on the left and right side of the tub. If the drum has come loose, all you should have to do is have someone assist you by lifting the tub up high enough to reattach the spring(s). CAUTION: The tub is very heavy due to the fact it has counter weights on the front and rear of the tub. Lifting may take some effort. Now...these springs usually have a small bracket covering the upper end that prevents it from coming loose. It is not normal for them to become detached unless the drum cracks at the spring support, or if you had a severely off balanced load that may have shaken it violently. In addition, if the support springs did come loose, you will need to inspect the perimeter of the door bellow (rubber boot) to ensure it did not become ripped or come loose from the tub as well. This will cause leakage. Please inspect your washer and get back to me on what you found, so that I may assist you further if needed.
Posted on Feb 18, 2009
Ghw9150pw0
Drum bearings gone..or Suspension unit that supports the full drum inner and outer.
Oct 28, 2013 | Whirlpool Duet 3.8 cu. ft. Front Load...
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.
The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
Dec 30, 2012 | Asko WL6532XXL Washer
Drum has dropped
the reear bearing housing is worn due to a seized bearing.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
I have a whirlpool washer lxr7144e01 the water drains out but it wont spin. It looks like the drum is not sitting level anymore. You can hear something runing under the drum.
the drum support spring/s have come off,,letting the drum drop a few inches,,take the top or back off and the support springs can be put back on or new ones fitted,,the springs fit into the top of the washer case and hook onto the drum
Jun 28, 2010 | Washing Machines
Washing machine motor not turning
hello,
what this indicate is that there have been a power disconnection from power supply on the jet string connected to the drum (drum controller)
what you will have to do to solve this problem is to unscrew the the washer then trace the wire down to the jet it is round in shape at the back of the washer
please rate this
thank you
Jul 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Lg washer tub hitting glass and making sparks
check the drum suspension springs (under the top cover); as sometimes they'll slip out of their holders. this will cause the drum to "drop'' and will no longer align with the door. also, check the lower drum "shocks" (inspect behind rear access panel) for damage too.
May 09, 2010 | LG WM-1832C Front Load Washer
Drum has dropped about an inch
sounds like the stabilizer arms that suspend the drum are broken or have come off you should be able to fix it yourself if you can figure out how to get into the machine i think you go from the bottom or there will be a panel to unbolt on the back
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Belt keeps coming off the pulley
I suggest you check your drum bearings, belt will only come off if misaligned.
Mar 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Drum dropped
Are you able to lift the inner drum back into position ? If so then the culprit is most likely within the trunnion or spin bearing assemblies. Dis-assembly can be tricky but it is possible to do this yourself.
Jan 01, 2008 | Frigidaire FWS1339A Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
374 people viewed this question
Sal De
fordexpert
Robert Rankin
