Question about GE PTS25LHP Top Freezer Refrigerator
Not cooling top freezer.model no ER-120F.I need detais of this refrigerstor.wairaing diagram,comprassor RLA,which refrigerant.
5 Suggested Answers
  • 4 Answers
SOURCE: maytag mfd2561he bottom freezer
I had the same problem. I removed the rear panel of the freezer (4 screws), removed ice maker, and found the evaporator fan that blows cold air from the freezer to the refrigerator was bad. I removed old fan and began calling around for the replacement part. Turns out the original encased fan motor went bad because the motor was encased and condensation caused the motor to go bad. The new motor came with brackets and new unenclosed motor. Took 1 screw driver and about 1-2 hours of work. Make sure power and water is off before working on unit.
Posted on Jul 22, 2008
  • 363 Answers
SOURCE: fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Posted on Jul 26, 2009
  • 363 Answers
SOURCE: error message ER FF - refrigerator is not cooling as a result
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Posted on Jul 30, 2009
heatman101
  • 43501 Answers
SOURCE: Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
rylee_smith
  • 8619 Answers
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2010
The control on the bottom freeser not working properly, the display number for the freezer is showing a temperature of 50 degee, where was at -4, now it is not freeze.
might need a new temp switch of you lost your freon wich will no longer cool like a ac in a car call a plumeing and heating guy to check ac level in the comprassor good luck
May 03, 2014 | Samsung RS2630SH Side by Side Refrigerator
My fridge is not working, freezer ok model no er 80341
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 22, 2011 | Refrigerators
The frezzer is freezing up and the icebox is not cold. the fan in the freezer is turning. model 106 74262400 serial ER 2922094 type 22TFA
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Kenmore Refrigerators
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator section not cooling: >60F Freezer has been ok. No obstructions to air flow. diagnostic codes displayed are: Refrigerator ER and Freezer section DH Model: LRFC21755 please...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 28, 2010 | LG LRFC-21755 Bottom Freezer Refrigerator
Fridge is no longer cooling. ER where the
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Kenmore Elite Trio Fridge - Getting ER F5 error on display
Er-FS error code: Failure of freezer sensor.
I have been finding the fuseable link in the defrost system on these models open preventing the defrost cycle.
This would involve removing the freezer back panel and removing the sensor and fuse from the evaporator.
It's just a plug in.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 23, 2009 | Kenmore 73503 Stainless Steel Bottom...
Frost free refrigerstor
use a little vasaline on door gasket and it will be better
Sep 08, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
May 19, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Maytag mfd2561he bottom freezer
May 14, 2007 | Maytag MFD2561HE Bottom Freezer French...
GE PTS25LHP Top Freezer Refrigerator Logo
46 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
