Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Kenmore Vacuum Model #37020 has VERY POOR suction!
Within three months of owning this vacuum we had to replace a belt...then we found out it was put together with the wrong belt!!! This is the worst vacuum I have ever owned! Sears won't take it back. I started talking with Sears before the machine was even one year old and they said they can't help me! What can I do? It was an expensive machine and it's a piece of ****!
  • vickylarson Feb 18, 2009
    I went to the Kenmore website and they had no email address for Kenmore under customer care. They had a phone number listed and of course that put me through to Sears. I was on hold for 30 minutes waiting to talk to someone in the warranty department. When they finally answered, the operator had put me through to the wrong department...the Nordic Track customer service! ARGH! I can't find a Kenmore number or email address anywhere. Does anyone know where I could find this?
  • 547 Answers
Get ahold of kenmore them selfs leave a complaint
Posted on Feb 18, 2009
  • albert getty
    albert getty Feb 18, 2009
    1 888 kenmore this is the number you need to call
What causes poor suction on model ud40270? It seems like a lot of air is blowing out the front where the filter is.
First, remove and clean or replace all of the filters in the machine. There is an inlet filter above the dirt collection cup. and an exhaust filter at the front lower part of the top of the vacuum head. If either filter is clogged, you'll get poor suction. Also lay the machine on it's back, and check the tunnel where the dirt goes up into the machine (behind the beater bar) to see that it is not clogged.
Jan 08, 2015 | Filter Vacuums
Why is my vacuum spitting out dirt as I vacuum?
Hi, it's Ambrai from Crucial Vacuum.
This usually means that your vacuum isn't suctioning properly. Your brush roll spins and picks up debris, but if it is not suctioned up, the debris will go back on to your carpet.
Poor suction can be caused by a clogged hose or a dirty filter. First, remove the hose from the vacuum. Toss a coin down your hose and if the coin does not come out of the other end, your hose is clogged and you will need to clean it. If it comes out of the other end, your hose is not clogged. To check if your filter needs to be changed, open the dirt bin canister and remove your filter. For optimal performance, it is recommended to change your filter every three to six months.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
May 07, 2014 | Kenmore Progressive Bagless Upright with...
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Dec 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Jul 07, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Suction only with attachments but none otherwise
Remove the brush roll and then fit everything back as normal. Then switch on. Put your hand to the sole plate - if you can feel suction coming through as you would normally vacuum then it could be a motor seizure. However if you can't feel suction then there's a clog between the main dust channel and the main hose pipe/where the hose comes out the back of the vacuum.
Once that's done then put the brush roll and belt back. You may find that the belt may have to be replaced if its broken.
Mar 27, 2009 | Vacuums
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore progressive upright canister vacuum
I had the same problem and so my husband took our vacuum apart. I cleaned what I could and discovered that there is a foam filter that sits below a dark gray cover immediately beneath the bag (on the floor of the inside of the vacuum). This is different from the HEPA filter. I cleaned this off (ours had a lot of dog hair on it) and placed it back in the slot. The vacuum is not making the noise anymore and the suction is even improved. I had not noticed the suction had deteriorated as the vacuum still worked well in my opinion. I hope that this helps and that you have the same problem. It was very easy to fix. I believe the noise was due to the impairment to the suction. Good Luck!
Sep 12, 2008 | Kenmore Progressive Bagless Upright with...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
269 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
