Question about Dryers
I have a whirpool dryer Mod#LER5620KQ1 the dryer makes a grinding noise when you turn the power on what can this possibly be
  • 547 Answers
Change the felt around drum
Posted on Feb 18, 2009
    President:
  • 1,902 Answers
Check for metal shavings under the unit pull off the back cover. It seems like this can be one of a couple things. Bad main bearing, your clutch is not fully disengaging or the brake is not disengaging
Screeching noise when the dryer is first started MOD.- 110.95087402 Gas.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 16, 2011 | Kenmore Dryers
I have a whirlpool dryer mod #LER5620KQ1 that suddenly went dead. Any ideas on what I need to do?
First thing yall do is check for reasons why the dryer would quit. The most common being air restrictions. themobilian_2155.jpg
Your dryer has a fuse right there beside the filter housing. When the drum temp exceeds 350f rapidly this fuse melts and kills power to the door switch. themobilian_2156.jpg
If the fuse is fine then check the door switch
I have a manual and more repair photos HERE
Apr 06, 2011 | Whirlpool Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Dryer doesn't want to run- makes grinding noise
its sounds like a worn bearing problem.with the m/c switch off ,turn drum by hand and see if it is hard to do so.if you get a gritty feeling in your hands or hear a grinding noise,then that is probably the bearing.
Jul 23, 2009 | Dryers
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Estate TEDX640PQ0 electric dryer makes grinding noise when running and seems harder to turn drum
heatman101
Apr 21, 2009 | Estate TEDX640JQ Electric Dryer
Grinding noise
In my humble opinion, a dryer making a grinding noise is worth repairing. Possible Problems:
Worn Drum Rollers (Very Likely): More of a thumping / grinding sound. Replacing drum roller supports is considered to be a routine "normal ware & tear" repair with parts costing about $15 - $20 or so. Its' kinda like a tune-up for a vehicle. The rollers can be located in a couple places, but are typically located on the inside rear of the drum; upon dis-assembling the dryer.
Broken/Loose Blower Fan Wheel (Likely): The blower wheel can become loose or brake off the motor shaft and can make a "rumbling / grinding sound and can run about $15 - $25 for the part. The degree is difficulty when repairing a little high, but is commonly performed.
* Note: Removing and threading the blower wheel is reverse to prevent the fan blower from natually spinning/coming-off "Righty loosey, lefty tighty"
- C
Jan 27, 2009 | Maytag Dryers
I HAVE DRYER GE MOD #DWSR488EB2WW SER#ZG743601A ***HAVE GRINDING NOISE. RELPACED THE BEARING IN THE BACK. BELT SEEMS OK. PUT BACK TOGETHER NOISE CONTINUED. THE NOISE HAS A SLIGHT GRIND/SCRAPE IN ONLY PART...
The most likely cause is the front drum supports. There are 3 or 4 teflon strips (about a half inch wide and 2 inches long) on the top of the front panel that the dryer drum glides on. When these wear down, the drum can scrape on the plastic that holds them or on the metal frame around the door frame. Another possibility is if the drum touches the dryer exhaust vent pipe, most often only if the dryer is vented out the bottom of the dryer and the vent pipe has shifted up just a bit, allowing it to contact a spot on the drum with each revolution.
Oct 02, 2008 | Dryers
Ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
May 20, 2008 | Dryers
Dryers Logo
180 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
