Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Loose drum on washer
Got maytag LSE7806A and drum is loose and will therefore not spin...HHHHEEEELLLLLPPPPP!!!
Thanks
Carl in London
  • mlord4 May 11, 2010
    a belt will not fix a loose tub more info mabe sock stuck in tub would stop it from spining mark in hamilton
    Genius:
  • 1,075 Answers
You do not tell me alot about the problem,so im going to hazard a guess; get your drum belt tightened or replaced this will fix your problemhope this helps.adrian
Posted on Feb 18, 2009
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Dryer tries to start but drum wont turn
You can turn it by hand but make sure it is unplugged!!
Jun 28, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune stacked front load MLE2000AYW
I'm trying to remove the top cover in order to relace one of the fins inside the drum. The screws came loose and let go. I'm struggling to get the top off. Which screws in the from need removed to release the front? Thanks.
Jul 13, 2008 | Maytag LSE7806A Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
598 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
