Putty - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
For most repairs the $199 is a little too high.
I would find an authorized independent servicer to take it into that charges a
minimum of labor to give an estimate. $25 to $40 is average for a quality
estimate.
Since it is a Sony do not take it anywhere that gives "free" estimates. A good
detailed estimate with the actual parts needed takes time. If the technicians
time is worth nothing to look at the tv set, what is it worth?
I have always been told if it is free it probably isn't worth anything.
From experience you probably have some corrupted data in the system control
that runs the horizontal timing system. More rarely I have actually seen a
problem in the jungle ic that actually creates the horizontal timing pulses.
Worst case if you were to bring it in to us $30 to get estimate. If under $90
we would fix automatically, this saves about $15 in labor charges if we have to
put tv back together while we wait for a return call after leaving message on
estimate. Most of these run under $90 except for jungle ic replacement, it
runs a little more.
This is no way means that this is a daiagnosis on your tv set as I would have
to take it apart and do several measurements. But I have seen these 2 failures
cause very similar problems several times.
David
