Question about GE Kitchen Ranges
Need parts for Hotpoint triple oven. bottom oven left side fuse holder and top oven thermostat Cat. #301HNA202 Ser. #B8381 220/240 KW 6.2
  • 10,865 Answers
Go to this page and you can order what you need at a reasonable price:
www.partselect.com/Hotpoint-Oven-Parts.htm
please rate my answer as a fixya!
Posted on Feb 18, 2009
Thermoststat defective need new one
they only make 2 types...normally open or closed 155 degrees + or -
use a VOM reed the old one if it shows open you need a normally closed thermostat..$5 or less
Apr 11, 2014 | Thermador 30 inch Masterpiece Series...
Hotpoint bd32 oven and top oven/grill what output does this have .and does it need 6mm cable connection or can it go on a plug
Hi.
You most definitely need a 6mm hard wired supply cable to cooker, anything less, and the cable will overheat .
Under no circumstances connect it to a 13 amp suupply and plug.
The total kw output can reach in excess of 4-5 kw, so it is imperative that you hard wire it to a seperate fused supply.
Jun 22, 2011 | Ovens
Wife ran for 14 min w/out anything in it changed fuse no luck
You need to change the cavity thermostat. The unit got too hot and blew the cavity thermostat. If this is a vent-a-hood model, it will be up under the vent housing at the top (must drop microwave to change) and if built-in, it will be on the left side under the outer cover. Just remove the screws from the back and sides and right along the edge along the bottom sides. Will have 2 wires going to it from each side. Just replace thermostat and reattach molex plugs. Then retest. Should be fine after that.
Jul 12, 2010 | LG LMV1630 Convection/Microwave Oven
Milwaukee blade holder replacement
piece of cake. the number you need is 14-46-1011 and the cost is usually between 15 and 20 dollars. it comes with detailed instructions and a exploded parts list for this. About 10 minutes tops. If I have answered your request would you please rate this response accordingly. and if you provide me with city state and zip I will try and find one locally for you if in U.S.
Sep 14, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
BRAVETTI CONVECTION OVEN MODEL K5345H
open by unscrewing screws on back and along left side bottom. this lets you swing up the cabinet showing the electrics. the red power line going to the timer is held in place by a metal wire holder that is riveted to the base. wire has a white sleeve between its insulation and the metal wire holder. slide wire and sleeve out to the side of the holder. slide sleeve to side along wire, revealing fuse. need a solder iron and an electronic parts store to get replacement fuse and solder it in. reassemble.
the fuse is a resistor that blows when unit is getting hot. use lower resistance fuse or just hardwire the power line straight through, no fuse, but watch for overheating (not likely) and maybe use breaker outlet
Oct 15, 2008 | Microwave Ovens
Changing the fuse in microwave hotpoint mosel JES636WKo1
This model seems to have a fuse in a cylindrical white nylon fuse holder, probably located near the right rear.
It will also have a thermostat on the magnetron which may be out.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
Aug 18, 2008 | General Electric Microwave Oven
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Delonghi
Changing bulb in DeLonghi ED 8525S-SBD
This is merely an account of how I fixed mine - do this at your own risk. The oven is full of high-voltage items which include large capacitors which are not discharged when you unplug it from the mains. You can still get a life-threatening shock from the charge which is stored in these components.
Therefore do not touch ANYTHING electrical except the bulb connectors.
1. Unplug the oven and place on a suitable surface 2. Remove the cover. This is held by five screws at the back of the of the machine. Three are along the top and are philips type and the other two are on the bottom left and bottom right corners and are star-grip. The cover must slide backwards first before coming off. 3. Find the bulb holder. It is located on the right of the oven as you look at it from the front. Turn the oven so that its right side faces you. The bulb holder is an oval black part with two electrical connections coming off it. It is about 6-7 cm long and 3 cm wide. It is mid way in the oven (from top to bottom) and a little towards the front. It is held to the oven frame with two bent metal prongs 4. Remove the electrical connectors by sliding them backwards. 5. Bend back the prongs and lift out the bulb holder. 6. The bulb in a 20W 240V oven lamp with a standard oven lamp screw-on fitting. 7. Replace the bulb. 8. Put the bulb holder back in place, bend the prongs back to secure it, re-connect the electricals. 9. Replace the cover and screws.
Jan 15, 2008 | Microwave Ovens
Hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Dec 09, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
