Question about Orion FTDV2004 20 in. TV/VCR/DVD Combo
Only 5 channels
I have a TVCR 1321A lost the remote. The TV is locked in to the channels 003, 004 006, 010 and 013. How can I unlock all channels or get to the menu without a remote? If I must have a remote, what brand is best?
    Scholar:
  • 135 Answers
Try purchasing one of the cheap "All in One" universal remote control handsets.
Posted on Feb 18, 2009
You need to press both volune controls at the same time and it will take you to the menu screen from ther you can yse the channel controls to do a channel scan and other adjustments. hope this helps
Posted on Feb 25, 2009
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
Mar 14, 2011 | Jensen 143307 Remote Control
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
Tv is not working it is stuck on channel 3 and stays there and need it to go on output in front and can't watch any channels with direct tv satalite very difficult lost remote and need code this tv and...
Hello
If you have its original remote control you can unlock its parential settings and reset it. Then only you can watch other channels also. I'm ver sorry to say that if you lost your TVs remote control, you will be unable to unlock it. Try to get a remote from any of your friends who owns the same model number RCA TV. If you are able to get it, do the following with that remote, and reset the V-chip. Try to purchase one new remote control from RCA.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK
Happy New Year
Dec 31, 2010 | RCA TruFlat 27F520T 27" TV
Kids locked up the TV, need code to unlock it.
Try this: press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
Apr 21, 2009 | Jensen JER-323 Remote Control
Child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
Apr 10, 2009 | Televison & Video
How to unlock some channels that locks by mistake on your remote?
is it a cable channel that is locked or a normal TV channel ??
if its the cable channel, you can always call your cable company and have them give you the unlocked code...
if its the TV channel... what make/model is your TV ?
Feb 17, 2009 | Daewoo DTQ-13P2FC 13" TV
Green lock and black screen
go to your menu and turn off the ccd and text modes to remove the box,as for your lock out code try oooo or 9999.
Sep 22, 2008 | JVC AV-27D302 27" TV
Orion FTDV2004 20 in. TV/VCR/DVD Combo Logo
438 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
