Question about Kitchen Ranges
I have a commercial Bunn CDBC coffee maker and its acting funny, in other words, after brewing a couple of pots, it turns off on its own and does not start. After maybe two more days, it decides to make maybe four pots this time.Before it turns off, the machine becomes very hot as though it's overheating. Please advice, Thank you. Brian
    Genius:
  • 1,550 Answers
First of all you need to check fuses that blows when excessive heat is detected,
Also chance main power switch could also be faulty . Heating element turns off when excessive temperature is sensed . The problem could be heating element .
Posted on Feb 18, 2009
  • 15,935 Answers
There is a thermal shutoff switch. It is faulty, or it is working properly, and turning the system off because it is overheating via a faulty thermostat regulator.
Replace the Regulator if the temp is getting too hot. This will solve your problem.
Thanks for using FixYa - a FixYa rating is appreciated!!
  • blueextc3221
    blueextc3221 Feb 18, 2009
    CLICK HERE for a PDF download of your manual.
    The link will only be good for 24 Hours.
  • 19,396 Answers
Check the power cable and the power plug, the most likely is that you have a bad solder joint inside the machine.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Better check the unit for any faulty ic, and capacitor on the power board
    President:
  • 1,902 Answers
Check your heating element inside the water tank and make sure that the element is not full of lime or calcium build up. Also make sure that the tempurature control does not have lime and calcium build up.
Why won't my bunn coffee maker turn on
You should check to insure that the tank inside the machine is full of water. Pour in 1 pot of water at a time until you get water to come out of the brew basket. If you haven't done any internal damage it should be ready to brew a pot of coffee inabout 20 minutes.
Sep 21, 2014 | Bunn 10 Cup Home Coffee Brewer
Pot wont brew the water is heating up but it wont go past that point
I hope this helps.
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Jul 26, 2011 | Bunn VPR Coffee Maker
Coffee tastes funny. does machine need to be cleaned?
Yes, in this type of machine, put a little bit of vinegar and water in top and run a couple times through machine, with of course filter basket on, not with filter or coffee, and brew a couple times. Use 25percent to water ratio, do this twice then do it again, twice with only mineral water. Then make a pot normal, and let me know how coffee taste now. Thanks Mr Bean Man
Jun 09, 2011 | Bunn VPR Coffee Maker
Need the back switch that turns the pot on to brew(carlingswitch) for model NHB
For Service Contact:
Bunn-O-Matic (800) 352-2866
They call it "Vacation Switch"
I work on commercial equipment (including BUNN), and they don't use any names like this one in the commercial line.
Jan 14, 2011 | Bunn NHB Coffee Maker
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee grounds in bottom of commercail size coffee maker
If you will call 800-286-6070 we can help you with this.
Nov 01, 2009 | Bunn 10 Cup Home Coffee Brewer
Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Feb 05, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
