Question about Dryers
Dryer will not start
Check fuses and door switch...no problems... was suggested to check switch but have no idea how to know for certain light in the drum is active all cables for power cord are secured
  • brown2181 Feb 18, 2009
    hwo do i get to either the belt or motor
  • 547 Answers
Motor is done or belt is broken so change one or other
Posted on Feb 18, 2009
  • 2 more comments
  • albert getty
    albert getty Feb 18, 2009
    motor is done or belt is broken so change one or other
  • albert getty
  • albert getty
    take off front of machine you will see belt around drum or motor is in bottom drum will come out when front is taken off
  • albert getty
    please rate me thank you
I have a Kenmore 800 model no. 110.69822801 dryer that stopped during a drying cycle. It would not start. I found helpful tips from your site and decided the door switch was faulty. I bought a new switch...
Check the thermal fuse, check the belt switch. If these are OK, check the timer. The timer troubleshooting guide may be located within the control panel. If the dryer still doesn't turn on, check motor winding continuity, and finally control board. Perform these checks with dryer unplugged. Most likely causes: Thermal fuse or timer. If thermal fuse is problem, clean dryer duct after fuse replacement.
Dec 18, 2014 | Kenmore Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Dryer won't start
it is one of 2 things,the door switch is bad or the heater box fuse is bad,you can remove the back panel and you will see the little fuse on the top of the heater box,if you have a meter you can check the fuse and the door switch on the ohms setting,ler me know-mike
Feb 15, 2009 | Whirlpool LER5636P Electric Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool dryer
The following link will give you some additional advice on how to troubleshoot a dryer:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Read through the link provided, thoroughly. It does cover many common dryer problems and how to diagnose them.
You know at this point that have power to the unit, because the drum light is working. Now...with the door open, does the light go out when you push the door switch in by hand? Is that how you determined the switch to be good? If the light does not go off, the switch may not be working properly and the dryer will not start. Another easy item to check is the thermal FUSE. The fuse is located behind the lower panel under the door. It is a white plastic component mounted to the top of air blower housing right under the drum in the front. There should be two wires going to it. If the thermal fuse is good, it should read a short (or close to zero ohms). These two first items I mention will kill a dryer from starting and are the most common problems to start with. Read through the section "Dryer Does Not Run at All" and let me know if require further assistance. I hope you find this information helpful.
Nov 08, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer will not start.
Check your door switch. It sounds like the door switch is not engaging (closing properly). If the switch contacts stay open, the interior light stays on the dryer will beep when you attempt to start it. This is the push button toggle switch on the door frame. This is a common symptom of this problem.
Open the door and push in on the switch, If the switch is working properly, the light will go out. If it doesn't, you will need to make sure the switch is not loose. Next, check the wires leading to the switch to make sure they are not loose, broken or grounded to the case anywhere. If all the wiring checks good, you will need to replace the switch. This is a very simple repair. Let me know if you require further assistance. I hope this helps you.
Oct 16, 2008 | Whirlpool Dryers
Whirlpool Dryer Model # LER7646EQ1 won't start
I'd check door switch first. Improper voltage, thermal fuse, start switch, motor, and wiring are also possibilities.
Nov 11, 2017 | Dryers
Dryer
Check the front door switch for a clicking sound; in no sound occur, change the door switch.
Nov 07, 2007 | GE DBL333EA Electric Dryer
Dryer not running has current
zedlast Did you check the door switch? If the door switch is fine, reset the circuit breaker. If it does not help then check the power cord connection to the dryer. One of two hot wires could be loose or burned out. If nothing of the above helped, let me know. Gendos...post back
Mar 03, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Dryers Logo
Top Dryers Experts
