Question about Remington Titanium SmartSystem R-9500 Electric Shaver
Remington Titanium R9500 cleaning unit does not work
Where do I purchase a replacement cleaning system (the base)? Mine has quite pumping the fluid and I would like to replace it.
How do you change power steering fluid on 1994 toyota pickup DLX with 4 cyl. engine
Should have done it when you had everything unhooked.
Rather than disconnect the hoses I use the trigger unit from a plastic spray bottle to pump the fluid out of the PS reservoir. Just unscrew the spray tip on the trigger unit, drop the tube section into the PS reservoir and pump out the old fluid into a container using the trigger. (If the plastic tube has a tiny filter on the end just cut it off before you insert it.) Then refill the reservoir and take the car for a short drive to circulate the new fluid. Then do it again. Empty and refill.
In a few days or a week, repeat the process (2 more empty and refills)and you will end up with nice new fluid in the system. If you like do it a 5th time in a week or so (1 more empty and fill) but at that stage you should find you are pumping pretty clean fluid out.
Not the most efficient system but it is very easy to do, takes little time and you do not need to go disconnecting pump lines which I would rather no do..
I do it this way on all my own cars every few years because it is easy, clean and works well and keeping the fluid clean and fresh means less wear on the pump due to contaminants and fluid deterioration.
If you get air in the system because you run the fluid level below where the lines fit to the reservoir don't worry. The air will be removed when you drive the car and turn the steering wheel back and forth. I don't run the fluid below the line connection when I remove old fluid from the reservoir.
Feb 28, 2015 | 1994 Toyota Pickup
What brake fluid is used is most vehicles with abs
A general DOT 3 brake fluid is use in small vehicles
Jun 11, 2014 | 2004 Pontiac Grand Am
Why is power steering fluid spewing out of the cap after replacing bad leaking power steering pump
You have Air in the Power steering System and it needs to be bleed out, And to do this if you Jack the two front wheels off the ground and Let them Hang free so there is No Load on the steering at all. please put some type of stands under the car, You will need more power steering fluid but before you add this you need to start your Car and turn the steering Wheel Slow from left to Right a few times, You will hear a wearing Notice come from the pump and you will see more fluid come out of the pump as well, that is the air trying to bleed its self out. The fluid coming out will be air rated lots of bubbles in it, Now that you have done this the Noise from the pump should start to go quite at this Point you can start to Add the New power steering fluid slow to the reservoir and keep turning the steering wheel from left to right slow (Never Fast but slow ) Have a lot of rags to clean the Mess. Hope this helps you. :)
Jun 08, 2014 | 1991 Cadillac DeVille
Where can I purchase fuse #45 for my chevrolet equinox lt 2007 in richmond, va
It sounds as if the windshield washer pump, located at the base of the windshield washer fluid reservoir, has lost it's seal. When this occurs, washer fluid seeps into the pump and shorts it out. I advise that you remove the pump to confirm this before replacing the fuse. A replacement wind washer pump and fuse can be found at your dealer, local auto parts store or the internet ( has always been a great source for quality parts at a very competitive price and I use them all the time). Hope this helps.
Mar 15, 2014 | 2007 Chevrolet Chevrolet Equinox LT
Precedure on flushing brake line in my dakota
The best way to really flush out the brake lines it to thoroughly bleed the system in the normal manner. You could disconnect the brake lines at all the possible points and blow them through with alcohol and then blow them dry with air, but the bleeding method is quite adequate, you should use at least a pint of brake fluid and ensure that you bleed each point until clear new fluid comes out of each bleeder point. Always keep the reservoir fill to avoid getting air into the system. This is something that should actually be done at least every two years as routine service and do not be lured ito discussions about DOT 3 and DOT 4 fluids. DOT 4 has replaced DOT 3 fluid as a superior upgrade to the older outdated fluid. Silicone fluids are available you would need to clean out and overhaul you complete brake system to use them. They are not compatible with Glycol based fluids.
Jun 03, 2011 | 1999 Dodge Dakota
My base does not pump cleaning solution thru the device. I will run the entire process, & there will be clippings in the bottom of the slot where the razor sits. The solution container is full, but...
The pump in the cleaning maching is broken. Pumps are not available seperately. Your only option is to purchase a new cleaning /charging machine. You will find this item for model 7570 available at See link below
Mar 06, 2011 | Braun Syncro 7570 Electric Shaver
I have a 2003 Pontiac gran prix. The windshield washer fluid quit working. The lines aren't froze. Power to the fluid pump is working. I replaced the washer fluid pump and it still doesn't work.What am I...
A crack in the tubing, clogged up sprayers on the hood. Check for leaks while a buddy activates the pump. Try cleaning the sprayers with compressed air. Listen to the pump, do you hear it working? If not, you have a bad pump or no power.
Dec 13, 2010 | 2000 Pontiac Grand Prix
Braun 8995 clean and charge stand
Use your Warranty. Or you could simply buy another one and return the Lemon one with the reciept for the new one.
Aug 17, 2008 | Braun Syncro 7526 Electric Shaver
New cartridge-wont pump cleaner
The cleaning fluid "pump" is actually a small Mabuchi 6V DC motor that uses two small plastic spur gears in mesh to "pump" the fluid up a tube into the cleaning reservoir. Mine has died also and I cannot find a replacement motor. The cheapest I have found the base is here: Good luck, Lynn Livingston
Jul 01, 2007 | Braun Syncro 7526 Electric Shaver
Remington Titanium SmartSystem R-9500 Electric Shaver Logo
777 people viewed this question
Top Remington Health & Beauty Experts
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
