Question about Car Audio & Video
I installed 2 12" volfenhag subs with a power cap and had it all put in and the inner speakers werent working so i switched em out and put in new ones and the subs wont work now. i poped the fuse and had to replace it with alum. foil. what do i need to do?
  • shortyssk8st Feb 19, 2009
    i triedthe amp on a differant sub and i got nothing. but i hooked the other sub up to the head unit and it pushed sound.
  • 77 Answers
I dont recommend using aluminum foil buy the correct fuses they arent exspensive. any auto parts store should carry most types. first check all of your power connections then check your ground connections if all looks and seems secure check the physical wire connections on the speakers. make sure the remote wire is connected properly. if none of this works try a different audio source to check the speaker itself
Posted on Feb 18, 2009
  • Ryan Lee
    Ryan Lee Feb 19, 2009
    sound like the resistors in the amp itself have fried this could be due to several issues. like i mentioned before i would never recommend using aluminum foil for any fuse replacement. It is possible that by using the foil you allowed a current which was improper and or shorting out to pass through the safety compliance ordinates of the amplifier itself. if this is the case which it does sound viable. being that you hooked it up to a different system and still got no sound check your subs on that system and if they work you have basically answered this question on your own. process of elimination wise anyways.
    Maybe a new amp is in order.
    a neat trick to try is if your looking for a new amp and happen to wonder in a stereo shop ask them for outdated or last years inventory and see if they can offer any deals. products are still good just not the latest out.
    Hope this fixya.
    Ryan
How do i remove the red ring protecting the screws from the sub so i can put it in a new box?
oh its just a rubber ring you just use you fingertips and peel it back one screw at a time. use a power screwdriver or a cordless drill and your fingers wont get as tired cuz its tough stuff-
Dec 11, 2010 | Volfenhag ZX-4812 Car Subwoofer
Not working
sure it is not your amp?? if so these are pretty cheap subs to just buy new.
Apr 21, 2010 | Volfenhag ZX-4710 Car Subwoofer
Sub box dimentions
12 " subs need 1.5 cubic feet sealed box...
Jul 17, 2009 | Volfenhag ZX-4812 Car Subwoofer
Like to keep this
Spkrs will sometimes be intermittent if the installer has twisted the frame a little or tighten down too much.Remove the spkr and see how it works when it is not mounted.If it still is not work right,then it is probly defective.Good luck and please rate this answer,thanks.
Apr 04, 2009 | Volfenhag ZX-4712 Car Subwoofer
Is my amp powerful enuff for woofer
That amp should work fine for that sub, but you should make sure that the amp has a good power system going to it, and the box for your sub is the right one. Either one of those things could cause problems if not done correctly.
-Dynami
Apr 02, 2009 | Volfenhag ZX-4812 Car Subwoofer
Subs not working but power to amp and cap are
when u press down on the cone do u here the speakers if u do and u have to let go off the cone and you dont hear noting just some bass im tinking ur subs are burn out(they dont work)
Feb 18, 2009 | Volfenhag ZX-4812 Car Subwoofer
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Amp protection light
is the amp well grounded run a wire from amp hosing to metal of car hope it work cheers
Jan 15, 2008 | Volfenhag ZX-7180 Car Audio Amplifier
Subs stopped working & protect light on the amp is red...
well at this point i would say it is both,, the subs fried because your amplifier passed dc [direct current] and fried the voice coils on your subs....return them if they are under warranty,, the amplifier sound like you either operated it beyound its specifications or it has a defective output stage allowing it to pass or leak dc....it turned the voice coils into the equivelent of the runners in a toaster oven....when an amp passes dc it is going to do so to whatever speakers you hook to it....so either bring it to a shop to be fixed/ return it to place purchase for exchange or throw it away.....or you will continue to experience the same problems....I am sorry..ps the amp goes into protection when it detects a short...[ the short is produced by the amp and it is detecting its own fault and putting it in to protection after it BURNS up your drivers....
May 16, 2007 | Volfenhag ZX-4712 Car Subwoofer
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
