Question about Systemax Venture PC Desktop
Montior turns off when hooked up to tower.
I have tried 3 different montiors, and all three do the same. They work till i plug into tower, then they turn off. My tower is a Systemax Venture. Can anyone give me some idea how to fix it?
    President:
  • 1,902 Answers
Remove the video card and try to put it back in. Make sure that it is fully seated. If that doesnt work, then try replace your video card
Posted on Feb 18, 2009
Where can i find specs for my systemax venture desktop
there are specs inside the case, on the bottom, for my systemax venture. there is also a serial number on the back of the tower, on the outside; however, i believe that the systemax desktops were actually assembled by tiger direct.com.
May 20, 2014 | Systemax Computers & Internet
I checked the power cord and the surge protector all the other things plugged up are still working. Is there a fuse or inward power supply that may be out?
Depending on the MOBO there may be a power fuse, Remove ALL power, open the case and take a look. Look for a In-line fuse near the PSU to MOBO (ATX?) connection. May be a bad PSU? Do you get anything when you push the on/off button? In the rear of the tower do you see a green light on the PSU? Any LED's? Maybe this will help: http://www.supportforyourpc.com/
Jan 15, 2013 | Systemax Venture PC Desktop
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
Apr 06, 2012 | Systemax Venture S519J (988868) PC Desktop
Cant open the pc to replace the HDD
Try to slide it back and then lift it up. Also look for some type of lock release that your tower may have.
Jan 19, 2012 | Systemax SYX Venture M110 ION Small Form...
I cant make this Systemax Desktop run multiple monitors. It has a VGA and a Digital but only the digital will work one monitor. Help
You have to have a dual monitor video card. What's the make and model of your video card? Or, two different video cards that are capable, not to mention a mobo that will handle this.
Jan 03, 2010 | Systemax Venture PC Desktop
How do you change a LAN port on a Systemax Venture B805 pc
This is a very unusual request. Most ethernet connections are the same type of plug. It should look like a large rectangular telephone type hook-up. Yuo cannot change this plug outlet.
Oct 06, 2009 | Systemax Venture PC Desktop
I have a Systemax Venture computer that is 3 years old. Just developed a problem. Turn the computer on and after 20 to 30 seconds the computer shut down. What is wrong???
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Systemax Venture PC Desktop
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
No Audio
I have a friend with a systemax, same thing happened to him.
Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
Let me know how it works out.
Nov 23, 2008 | Systemax Venture S519J (988868) PC Desktop
Systemax Venture PC Desktop Logo
82 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
