Question about Kenmore 24032\24036 Top Load Washer
I have a kenmore elite mod no 11021062000. Spin action is noisy in all cycles and usually results in shut down with code SL. When extended spin cycle started, it recycles continuously and does not shut down. 4 suspension ties seem firm. Balance ring replaced because it was cracked. What is probable cause?
  • 188 Answers
I believe SL is suds lock. There may be something stuck in the drain pump which can also be causing the noise.
Posted on Feb 19, 2009
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 110 washing machine thermally cycles
Does it operate properly if you or something holds the switch down? If yes, then extend the end of the lid switch with hot glue, epoxy, or silicon glue to allow the switch to be pressed sown further. You can also build up the contact area under the lid if you choose--same result.
Aug 07, 2009 | Washing Machines
Noise during spin cycle
The suspension springs are not expensive and is usually the problem with a noisy (unbalanced) spin cycle.
Aug 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Jan 20, 2008 | Kenmore Elite 21086
Kenmore 24032\24036 Top Load Washer Logo
111 people viewed this question
Sal De
fordexpert
Robert Rankin
