No power to washing machine. checked the fuse in he plug. circuit breaker and plug socket also checked for loose conection wires in washing machine all ok. it started by the washing machine whilst not in use made a loud noise then power circuit breaker tripped the kitchen electric supply. swiched trip switch back on in kitchn everything else worked but not the washing machine. washing machine about 4 years old.
  • 4 Answers
Go go power rangers....
Posted on Feb 18, 2009
No power to Whirlpool awo/d5727. I have checked the fuse and the socket but still have no power.
You say you checked "socket" and the "fuse," did you mean the AC wall outlet (115V) and a fuse or breaker in the main power panel?
Nearly all circuits involving water are protected by a Ground Fault Interrupter that can be servicing several wall outlets (perhaps one not near the washing machine) or can be located as part of a circuit breaker in your main power panel.
The GFI outlets will have one or two push buttons located between the outlets and a combination GFI/overcurrent breaker will also have at least one button where others will have none.
If you find one that is tripped, try resetting it. If it will not reset, unplug the washing machine and try again.
If it now stays on, your machine may have an electrical path causing it to trip and using an unprotected outlet may be unsafe and an indication that the appliance itself may have electrical leakage which could be otherwise dangerous.
The circuit breakers in the main power panel can also fail (they didn't 20 years ago) and we have replaced 3 in a home only 5 years old already so they are not made well anymore.
Jun 22, 2013 | Whirlpool Washing Machines
Hotpoint TDL 52P trips RCD at fuse box when switched on at socket
hi martin it sound like bad earth this could be anythink check the plug for loose wire check the socket for loose wires if check motor wire in the washer also check circuit board connections if all wires are ok you could have a faulty motor hope it helps
regards
shaun
Nov 14, 2011 | Washing Machines
Did a load of wash it shortcircuited are breaker box and now when you try to plug it in it sparks...won"t turn on
You may have a bad circuit breaker in that box, or a bad wire, or a bad connection in the outler or in the washer plug or a loose wire where the plug connects to the washing machine.
Turn off the power to that circuit and check each component until you find the loose wire, or the bad component. Joe
Feb 23, 2011 | Amana NTW5400TQ Top Load Washer
Hoover 0910dryer not heating. element replaced not long ago
Hi, the possible causes are: Possible Causes: The wall receptacle, power cord (plug) and electrical supply must be in good condition and wired correctly for the dryer to heat.
  • Supply Issue - Loose or missing connection on supply wire from circuit breaker.
  • Plug Issue - Loose or missing connection in the wall. Defective, worn or damaged wall plug.
  • Cord Issue - Loose, missing or incorrect connection of the power cord to the dryer terminals.
If gas dryer and does not heat, Gas Dryer heats with a gas burner, make sure the gas supply line valve is open.
Also, for electric dryer,
Electric dryers require two 30 amp breakers or fuses in the house electrical box to run and heat. If one breaker is tripped or one fuse is blown, the motor, the timer and lights can work but the dryer will not heat.
May 01, 2010 | Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Power light doens't go o
Plug a working lamp in the washer power outlet. If it lights, the problem is within the washer (look for a breaker button on the back of the machine). If the lamp doesn't work either, look for a bad breaker, a loose neutral wire connection, or loose wire connection on the breaker. Check the wiring on the washer end as well.
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
My whirlpool washing machine wont turn on. I checked the fuse and the socket which are working perfectly well. It doessnt seem like there is any power in the machine.
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 17, 2009 | Whirlpool Washing Machines
Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
May 11, 2009 | Washing Machines
Washing machine causing power failure in whole
Best answer to this is the circuit outlet is connected to is overloaded < to many items are plugged into it > could be 15-20 watt breaker and usage amounts to more than wattage allowence. If you can lighten the load on circuit by removing things < t.v.,appliances,lights,etc.> from the other outlets that are affected < shutting down when breaker trips > then you can compromise and use washer any time. The other suggestion is to dedicate a breaker to washer, < by adding breaker and wiring to outlet for washer >.
Apr 22, 2009 | Washing Machines
Washing Machines Logo
549 people viewed this question
Top Washing Machines Experts
