Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Cant connect to my wireless network anymore???
My HP pavilion laptop dv2000 has worked fine for two years with my wireless setup, my other computer and childs PS3 still work fine but my laptop cant find anynetworks, when i try to connect to a network windows says it cant find any networks (The Blue light on the front of the laptop is on so the wireless should still be on), when i click on the diagnose option i get a screen up that says This computer does not have a wireless network adapter installed and configured. Please help AAARRGGHHH!!! Comment posted on Feb 18, 2009 Hi ive gone to my device manager, i have 3 network adapters 1, bluetooth device (personal area network) 2, Bluetooth device (RFCOMM Protocol TDI) and 3, NVIDIA nForce Networking Controller, I dont know if something has been kicked out or not or if something else should be there, i did a system restore back to last Friday when it was fine and had no luck, im not too brill with comps but am tearing my hair out, further help would be most appreciated thanks
  • james_cam923 Feb 18, 2009
    Hi thanks for that i will give it a try, just thought i would add, the problem arose when i had my lapton on (inplugged) the battery ran out, normally i just plug it back in start windows normally and everything is fine but on Saturday this wasnt the case, would you suggest the above to rectift this or does this shed the problem in a different light thanks
  • HP Master
  • 19,396 Answers
NVIDIA nForce Networking Controller drivers may have messed up your network drivers , since your network card is broadcom or intel pro, and it is not there.
Try reinstalling the wireless lan drivers.
You can download the wireless network card driver from link below:
Select software and drivers
In there you find different wireless drivers, download and install them all, the computer will automatically chose the correct ones.
You will have to enter your wireless network key again after reinstalling drivers.
Posted on Feb 18, 2009
  • 218 Answers
Read this article, then call HP at the number given. You may be able to get a free repair.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Posted on Feb 19, 2009
  • Tom Dresel Aug 12, 2013
    Can not get this link to work.
I cant add roku as a new device to my laptop and the microsoft will not let me updated
1. Enter your wireless router setup page using a computer that is hardwired to your router.
2. Go to your Wi-fi protected setup options and disable Wi-fi protected setup (WPS). Apply this change.
3. Go to your wireless security settings and select your desired WPA or WPA2 security mode and your desired password (psk). Apply this change.
4. Go to your Channel and SSID settings tab and RENAME YOUR SSID. Apply this change.
5. Now view your wireless networks on your upgraded Windows 7 machine.
6. Select the newly named network.
7. Select "connect" and enter your new passkey/password.
Let me know if this works for you.
tony
Feb 10, 2013 | HP Pavilion dv7-1240us Notebook
I can't get the onboard network connection to work. Wireless works fine. When I look at properties it says that it is connected.
The Ethernet jack might have a broken wire inside the laptop. Try a modem that uses a USB connection instead of Ethernet - if it works, then the Ethernet jack has an open wire.
Nov 11, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Wireless device disabled and cant enable
Hi:
I don't know the background on your DV2000 laptop, but if all of the sudden, your wireless stopped working, and now you can't enable it, I have some info for you. Here is the link from HP, but there is a known problem with certain motherboards in HP laptops, and one of the first symptoms is the Wireless stopping. Many of the laptops had enhanced warranties from HP for free, but
Check this out.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&product=1842189&docname=c01087277#
Oct 24, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
How do i get it all back
download the wireless drivers from internet....
Jul 12, 2009 | HP Pavilion dv2000t Notebook
XP on HP Pavilion dv2000
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
For the laptop with no hard drive detected, this is most likely because Windows XP does not recognize SATA drives by default, which the laptop most likely has. To solve this, you will need to enter the BIOS setup utility (most likely Delete or F1 on startup). From there, you will need to change the drive mode to Compatibility mode. I'm not sure where this would be, but if you check in your laptop manual, you can probably find this somewhere.
For the 2519TU, download and install this for the LAN driver: ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30264.exe it should work just fine.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
My HP Pavilion dv2000 web cam just stop working
You can download latest drivers for your camera from www.hp.com/#Support
Dec 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
456 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
