FixYa.com
Tags:
OCZ Ultra 5+
Soyo P4S Dragon Ultra problems
By LiZzIe - usenet poster
I'm having similar questions about my Soyo P4S DU Mobo: P41.7 Willamette
256MB Corsair 2700 Numerous PCI cards 300W Enermax PSU
I've downloaded the 2ba2 BIOS from Soyo and not running XP on Hi-Point but
on IDE 0, so the Hi-Point isn't my issue, as far as I know. Here's my
problem:
I can run only up to 108 FSB through BIOS, regardless of voltages, anything
higher won't beep or POST. I can set the BIOS @ 133 FSB and it "sticks" in
the BIOS after reboot, but doesn't boot up at that -- in the BIOS as it
POSTS it shows 1.7 (100MhZ x 17) and likewise in Sandra. The memory settings
don't seem to affect it, and I can run the DRAM divider @ 3:5 when @ 108FSB
giving me a stable 182 on the DDR, except that I can only cold start.
Is think this is a Willamette issue with the BIOS? The jumpers likewise
refuse to beep or POST at anything over 100/100, although I did get them to
boot up once at I think 133/100, but again, it was only recognized as
100/100.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Janice
Janice - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i havent been able to get my memory timings to fast or turbo without
winxp rebooting at times im still working on it... my memory score
is 2219
100/166 mem timings normal
ALU 3686
FPU 990/2341
Now all i gotta get is the mem timings correct and i will be happy...
i have 3 sticks of that memory and i am going to bench all 3 and see
which 2 are the fastest
are there any good mem benches besides sis
TIA
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
I run with a 1,8 Wil. and can only get to 112 fsb then it wont post anymore
(bios 2BAA1
Have just ordered a NW 2.2 and wil try to see if that changes anything
Have anyone tried to OC the NW 2.2 - and how far will it go on a P4S?
"Steve" <Somewhere@overtherainbow ...
Solution #3
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
I have not done any real benchmarks on this set-up yet. I am still trying
to determine how fast I can push it without hosing Windows. I'm still at
the "boot to DOS with HDDs disconnected" stage. That's why I'm looking for
a DOS Util that can read the speed of the PCI bus. Soyo have been remiss in
not showing this information in the BIOS screen. I need to work out at what
FSB the board switches from a 1/3 to 1/4 PCI multiplier. I know my AGP card
is good to 100 MHz, but the Highpoint and SiS IDE can be finicky with PCI
speeds, especially when DMA transfers are involved.
However, I do have some Sandra 2002 (2002.1.8.59) memory scores from my old
1.6 Willamette with some CAS2.5 PC-2100 Crucial DDR (Win98 SE). The OCZ
will give similar scores if the same settings are used:
100/133 MHz FSB/DRAM
Normal Timing = 1825/1818 (ALU/FPU)
Fast Timing = 1859/1829 (ALU/FPU)
Turbo Timing = 1855/1836 (ALU/FPU)
100/167 MHz FSB/DRAM
Normal Timing = 2116/2093 (ALU/FPU)
105/140 MHz FSB/DRAM
Normal Timing = 1919/1900 (ALU/FPU)
Fast Timing = 1964/1936 (ALU/FPU)
Turbo Timing = 1979/1945 (ALU/FPU)
105/175 MHz FSB/DRAM
Normal Timing = 2232/2206 (ALU/FPU)
Fast Timing = 2254/2221 (ALU/FPU) - some video corruption in Windows
There was plenty of stuff running in the background and these are single-run
numbers that I happen to have on me, so these are only ball-park figures.
Yours should be slightly better if you are running without the background
apps.
In any case, Sandra is not a good benchmark tool. I have done 1 run of
MadOnion's PCMark 2002 (#), but
that's about it. When I find the "sweet spot", I'll be running proper
WinBench @ Quake tests.
The Crucial starts losing data integrity (in Memtest86) at about 139 MHz
(Turbo Mode), 182 MHz (Fast Mode) and 183 MHz (Normal Mode). The OCZ starts
to lose it at about 193 MHz (Fast Mode) and 205 MHz (Normal Mode). I have
not had time to test the OCZ in Turbo Mode yet, but so fat it is good to 176
MHz.
So far I am well impressed with both the OCZ memory and the Northwood P4. I
may have a different opinion when I move onto the Windows tests, but that's
a story for another day...
Al.
"Instructions are only for people who don't know what they're doing"
Bob the Builder - Can we fix it? (2001)
All messages sent to me will pass through Spamcop.
If you Spam me, you will end up on a black list and
your ISP will receive an automatic complaint report.
In any case the Spam will not be read before it is trashed.
If you STILL want to Spam this address, here are
more people that would love to hear from you:
Solution #4
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
Why wait??? Take a 1.6A or a 1.8A and clock them at 133mhz. That
will have them running at the 533mhz. The 1.6A is now a 2.133ghz
533mhz FSB and the 1.8A is now 2.4ghz 533mhz FSB.
The northwood processor is very overclockable. I have two of the
1.6A's running stable at the 2.133ghz at default vcore on a 645 MSI
Ultra (6547) motherboard with samsung PC2700 DDR.
Thus I gave a
P-IV Northwood at 2.133ghz, 533 quad pumped FSB (133mhz clock)
DDR is PC2700 clocked at 333mhz (Memory is 4:5 ratio).
Agp clock is 66.6mhz and PCI clock is 33.3mhz (Fully compliant)
These systems are extremely powerful.
Steve
Solution #5
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
thats another... im stuck to deciede if i should upgrade to a NW or
stick to my 1.9Wil i kinda want to wait til the (533) bus P4s
comeout... btw Al... can u post ur OCZ mem bechs I have the 2700 rev
1.. (which i might replace soon) and i wanted to know if my benchs were
ne where near what they should bethankx
Solution #6
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
Hi Will,
The 2BA2 BIOS does not seem to work well with Willamette P4s. I had a 1.6
that would overclock to about 115 MHz FSB using BIOS 2AA2. Windows was
reasonably stable at up to 112 MHz FSB, but it locks up after 24-48 hours at
that speed. I flashed to 2BA2 and it would not boot at anything other than
100 MHz FSB. A CMOS reset was all that I could do to get it started after I
set the FSB to 102 MHz. Others have had similar problems. See the thread
entitled "new p4s bios... ne one use it yet???" for more details.
Last night I upgraded to a 1.8A Northwood and 256 MB OCZ PC-3000 rev 2.
Using a modified version of the 2AA3 BIOS
(#) this boots and runs
Memtest86 cleanly at up to 138 MHz FSB (not had time to test Windows
stability). However, if I set the DRAM clock to anything above the FSB
speed when the FSB is set to 133 MHz or above, then it fails to boot.
It will work with 132/176 MHz FSB/DRAM (Turbo Mode) or 123/205 MHz FSB/DRAM
(Normal Mode), but 133/166 MHz FSB/DRAM fails in any mode.
Someone going under the name of "me" has posted that the 2BA2 works well for
him (he is using a Northwood). My (as yet unproven) theory is that the 2BA2
works great for Northwood P4s, but has a problem with Willamettes. If I
were still using a Willamette, I would definitely stick with the 2AA3
version.
Now that I have a shiny new 1.8A, I am going to try the 2BA2 BIOS some time
this week to see if it fixes the 133 MHz FSB/DRAM problem. I'll post the
result when I'm done testing.
Al.
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
