Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Echo chainsaw how do you remove the clutch from an ehco cs400evl?
  • 2,176 Answers
OK I looked at Echousa.com and see that there shoule be a hex nut on the side where the clutch is. It doesn't specify whether it is left or right hand thread. but what I used to do is we have a plastic plug to put in the cylinder to stop piston from moving and then putting a ratchet on the hex nut. without the plug you can try an impact wrench to BUMP the nut in forward and reverse to remove it. Make sure the switch is off before attempting either action. You can look at the manual or parts explosion at the site I listed
Posted on Feb 18, 2009
Replace clutch spring
You need to remove the clutch assy from the chainsaw prior trying to replace the spring. Be aware that the clutch assy is no longer available so be careful not to damage it on removal.
Mar 01, 2015 | Echo Garden
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
Brand new chain saw bought from reputable dealer. The CS600. It was missing a part on the oiler and dealer fixed. Now the clutch overheats badly, to the point it acyually smokes. Does Echo have a policy...
Not had a lot to do with Echo, but have always heard good reports, for smoke to come from the clutch cover the clutch would have to be slipping, either due to running with the chainbrake on, or useing with a very blunt chain. To make sure the brake is off, pull the hand guard fully back to the top handle.
Apr 04, 2011 | Echo CS600P Gas Chainsaw 20 Inch
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
Where would i get a sprocket for aecho 451vl
You have a lot of options if a drive sprocket.
Oregon Bar & Chain Selector (input CS-451 for model number)
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Echo.com
OM
http://www.echo-usa.com/pdf/documentation/CS451vle_010178.pdf
IPL
http://www.echo-usa.com/pdf/documentation/CS451VL_010183.pdf
Page 3; item 4; pn 17500503431 - changes to 17500514330
She has an outboard clutch. This is a guide for removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
It lists a special tool for clutch removal, see the IPL, page 15; item 16; pn 89750502830 - changes to 89750516133. Please verify ALL part numbers provided.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 07, 2010 | Echo Garden
Replace the oil pump in a Echo CS4400 Chain Saw
An IPL for a CS4400 Chainsaw can be found here (there are multiple IPLs, please ensure this is your saw):
EchoUSA
http://www.echo-usa.com/documentation.asp?Model=cs4400&lang=E
There is no sigle illustration of all oiler components, they appear on multiple illustrations.
From the IPL it has an outboard clutch, it appears the oil pump is behind it. Use this a guide for clutch removal:
You can reply below with any questions if you need additional help. I hope you found this most helpful.
Lou
Jan 31, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Where do I find the proper tools to remove the clutch assembly for an ECHO CS-345 chainsaw? I would also need a tool made to fit into the flywheel fins to prevent damage to the crankshaft while removing...
MOST OF THE TIME I USE A AIR GUN AND A AIR WRENCH .IT DEKIVERS THE FORCE WITH OUT BREAKING ANYTHING. A 3/8 INCH BUTTERFLY GUN WORKS WELL FORN THESE SMALL TASKS
Aug 26, 2009 | Echo Garden
Echo sc 4400 Chainsaw blade turns constantly
If lowering idle speed does not stop chain broken clutch springs will cause chain to not stop
Jun 10, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do you replace the chain drive sprocket on an Echo CS-440?
you need to replace the clutch, you woould pull the side cover off and remove the bar and chain. then you remove the nut holing the clutch on( the clutch and sprocket should be on piece) take it to your local saw shop and grab a naw one.
Mar 18, 2009 | Garden
How do I remove the clutch on an Echo chain saw??
Backwards to the rotation of the motor, all you need are basic tools to do this.
Dec 16, 2008 | Poulan Pro Chain Saw 46cc 20"
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
157 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
