Samsung washer p801 1 year old need shaft on back of ss tub in canada near toronto whear can i get parts ? thank you
    President:
  • 1,902 Answers
Repairclinic.com. They have the parts for your machine. You can even call them and they will assist you
Posted on Feb 18, 2009
Try Amons 905-527-2008 or Amery 905-560-2673 both suppliers for local Hamilton service shops
Posted on Aug 01, 2010
  • AhmicDesigns Aug 01, 2010
    try alsohttp://www.apwagner.com
    but note that as of 2010 the SS-tub and the outer plastic shell have been discontinued ....
Need parts for Freud JS 100A Joiner Machine
Hello Sashaysin---
My name is Larry Boccioletti my company's name is Halton Maintenance near Toronto Canada.I am a Freud dealer here.
If you would like a quote I would be happy to oblige.
just send a request to
haltonmaintenance@yahoo.ca with the serial number and the part numbers you need and we will go from there.
Thanks
Larry
vqcooe
Feb 05, 2013 | Freud Tools & Hardware - Others
I have a whirlpool Duet washer model GHW9150PW0 that began to thump during the spin cycle. I removed the front and it appears the inner tub is off-center or out-of-round. Further, it has worn off the...
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our washer is leaving a greasy residue around and on the top of the drum.
If the age of your machine is over 10-12 years old, you could have a model that uses a transmission and the trans is leaking. If it is the transmission, it could be about a $150+ part.
Older washer designs used a motor to drive a transmission to agitate and spin the wash tub. As these get older, some develop small holes in the drive shaft (up under the agitator) which lets the trans grease get into the wash water. Our old washer lasted 23 years before the tub started to rust, so we decided it was time to get a new one, rather than put money into such an old machine.
IF your washer is older than 15 years, it might be starting to develop some other issues, such as rusting tub, etc., that could be costly to replace those parts, like the transmission, so you need to determine if
you want to repair or replace the machine.
If you can provide a model number, with all the alphas and digits, including the pre-printed ones on the label or tag, it could be confirmed that your washer uses a transmission and that is the likely source of the grease you're seeing.
Hope you find this Very Helpful and best regards!
Aug 23, 2009 | Whirlpool Washing Machines
WE HAVE A FRONT LOAD WASHER "KENMORE" 8 YEARS OLD. RECENTLY IT'S MAKING A VERY LOUD NOISE WHEN SPINNING AND BROWN OILY RESIDUE COMES OUT OF THE DRUM STRAIGHT ON THE LAUNDRY. WE TOOK THE WASHERS APART AND...
the water swelled the shaft of the spin surport..you should have recieved the wash basket under warranty,,,the back tub bearing you have to by,,even and you can knock the basket out,,it wont do you any good because the tub seal its in that back bearing tub and it had a leak,,,but if you have to..set the plastic tub on the edge of a solid table,,,shoot your wd 40 duwn the shaft,,cover spin end of shaft with wood,,,and hit down slow and steady..onthejob
Jan 17, 2009 | Kenmore 43052 Front Load Washer
I need a part for my TL200 docubind machine
thank you for your quick response, my secretary was able to find a provider here in Toronto after much network surfing so our problem has been resolved.
Once again thank you!
Deborah
Jan 06, 2009 | Office Equipment & Supplies
Kenmore Tumble Action Washer won't go to spin cycle
im a repairman,lets reason this out.if washer wont spin because the tub is so warped that when it spins its so out of balance then ok new tub.or the tub welds are broken and some part is dragging and not letting it spin then ok new tub.or spin bearing has failed and ruined tub support shaft,ok new tub.but why else would you need a new tub for a no spin problem,not sure,and to answer your other question , can you fix the tub if any of the above problem exist.no you would have to replace tub.i hope that helps,God bless ,tom....ps if i have been helpful please remember to help me with my ratings,tom
Jan 06, 2009 | Kenmore 43142 Front Load Washer
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Bad bearings on front loading lg washer 1832cw
Sorry, but you are not so lucky. LG should not even offer those parts, as it takes special hydraulic presses to install some of that. For anyone but the manufacturer them self you must replace the back half of the outer drum (I believe it is a 3045ER0008C in your case) which contains the installed seal and bearing, plus I'd recommend replacing the spider asm 4434ER0002A, as the shaft may be a bit worn where it contacted the seal and bearing, and you don't really want to go through all that work (at least 2 hours) only to have to do it again. A FixYa rating would be appreciated. Thanks.
Nov 12, 2008 | LG WM1814CW Front Load Washer
LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Jun 14, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
224 people viewed this question
Top Washing Machines Experts
