Question about Dewalt DC011 AM/FM Radio
DeWalt DW911 Dis-assembly Problem
I am having trouble seperating the cabinet on the DW911. I removed all the screws shown in the product breakdown provided on the DeWalt site, however, the seams appear to be welded or glued shut. Is this the case? If so, does anyone have any advise as to how to seperate the case?
Look on the back of the radio theres two more screws by the mounts for the cage
Posted on Mar 26, 2009
Does not spin
Could be a bad lid switch or deive coupling. This video will help.
Aug 01, 2011 | Whirlpool LSR5132PQ Top Load Washer
Can't get the compressor to fill both gages are at o
There are a few items that can fail. This is a belt driven pump so the belt may have broke. It also uses a pressure switch which can fail. The pump itself could have a scored piston/sleeve assembly although that is not as likely. There is also a valve plate that uses metal flapper valves and if one of the valves breaks it will not build up any pressure. You will need to remove the pump assembly from the tank and disassemble the pump to check these areas. You can view a complete parts breakdown by going to servicenet.dewalt.com as DeWalt owns Porter Cable. Here is a link to the page;
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=C2002&selectedType=22538
Jul 16, 2011 | Porter Cable C2002 150 Psi 6 Gal...
DeWalt DW911 cabinet seperation
go to www.dewaltservicenet.com
shearch by model DW911 loock the break bown
Feb 16, 2009 | Dewalt 18 Volt Compact Drill Kit
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Dewalt dw911 radio
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP)......works great now!! Many thanks to all of you who posted suggestions on this great website!!
Jun 05, 2008 | Dewalt DC011 AM/FM Radio
How to change a nozzel
to change the chuck you must remove the screw inside chuck by turning clockwise as it is cross threaded then place an allen key in chuck tighten and hit several times with hammer till chuck lossens
Feb 23, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt radio dw911
Have you changed the AA Batteries, this is often the fault, when they are flat they lock the radio out. HHM Dewalt Service
Nov 27, 2007 | Dewalt DC011 AM/FM Radio
DEWALT DW911
2 screws sunk in at the back left and right. no need to remove speaker screws.
Oct 27, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
806 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
