Question about Microwave Ovens
How to defrost
I now have mothers model wmw 18008 counter top microwave without instructions. can i find out how to defrost in it.thank you
  • BarbRiccio DenDunn Feb 18, 2009
    hi... yes it does have defrost button...... in fact it has 3. Above the buttons, it says "auto defrost by weight" then 3 buttons to choose from: Fish, meat, poultry.... then you have to do other things to start it but I don't know what? I can't find a manual anywhere.
  • My reply is May 11, 2010
    May sound a silly question but does it have a power control level?
    Scholar:
  • 135 Answers
Can only suggest trial and error to "Start it".
Since it belonged to ***********, would she know?
Alternatively, use the lowest possible power setting instead of the defrost function but take care not to "Over defrost" if using this method.
Posted on Feb 18, 2009
What is the wattage for the white westinghouse microwave model wmw 17778
Open your microwave door and look on the top or bottom, it should be on a sticker.
May 11, 2017 | Westinghouse Microwave Ovens
Does the ge spacesaver xl1400 microwave have to mounted or can it just sit on a counter?
Theoretically JVM1400-series microwaves (XL1400 is a meaningless number they put on the ovens) can be used on a counter top, but it's really not safe because it has no feet, and it may slide and fall off the counter.
Also, it will probably not set level on a counter.
You can download GE owner's manuals and installation instructions here.
If you need mounting hardware or other parts, you can get them by by entering your full model number from the tag on the oven here.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need instructions for the Bond Helman, (Personalized Products) Defrost Master 2000 Model # DM-02000. Can you please tell me where I can find the instructions for the defrost master?
Margi_smigie to use your Defrost Maagic 2000 just put hot water in the bottom pan, place frozen food on top and it will defrost. Turn over about half way through. Good luck. I have the mailing address for the company. jellybeanone@verizon.net if you have any questions.
Aug 31, 2010 | Microwave Ovens
How do you replace the interior bulb in a Model JVM3670BF08
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
hope this helps dont forget to rate this
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Control panel light
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Sep 06, 2008 | Sharp Microwave Ovens
Bought a new GE microwave MCD11E3W/MCD11E3B and the installation instructions and brackets were not included. the back bracked is there but it just would not hold the microwave. notice a few holes on...
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Microwave Ovens
Microwave Ovens Logo
231 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
