Question about ViewSonic N3000W 30 in. HD-Ready LCD Television
Standby ?? no Power ?? no Working ?? Hans from Germany DANKE
  • ViewSonic Master
  • 5,568 Answers
Gruesse ;-)
Power supply failures are too common in later sets and I suspect that is what you have. The supply is normally on a separate board and can be replaced by the owner if you can find one to buy.
Remove the back panel of the set and look for a smaller board with larger parts on it that seems closest to the AC (wechselspanning) input.
If you replace it, do not throw the old one away, look for a repair company, the cost shouldn't be more than 75% of the new one and you will likely need to have a spare.
Viel glueck!
Posted on Feb 18, 2009
Tv turns on and goes out in a few minutes
Posted on Apr 09, 2010
Who created the first jet engine?
The first jet engine was actually created separately by two different scientists who had no idea about the works of the other. These scientists were Dr. Hans von Ohain of Germany and Sir Frank Whittle of England. The first one to fly a jet engine was Dr. Ohain, who flew his jet in 1939. Two years later, Sir Frank Whittle flew his jet. For more information on the history of the jet engine, check out this website: http://inventors.about.com/library/inventors/bljetengine.htm.
Aug 29, 2012 | Champion Sport & Outdoor - Others
Hallo und guten abend, habe den olivetti extreme 423x notebook neu installiert und benötige die treiber wie grafiktreiber ? für eventuelle hilfe vielen dank im voraus
Hallo, sollte diese Ihnen helfen. Viel Gl?ck
http://www.free-codecs.com/download/k_lite_codec_pack.htm
Wenn das hilft Ihnen bei der L?sung Ihres Problems, beachten Sie bitte, mir eine Bewertung von 4 und vielleicht auch ein "Danke" Es wird gut helfen mir. Danke.
Dec 03, 2010 | Olivetti Xtrema 323S (BG0611 003) PC...
I have a gateway 300 s computer and it was working just fine till I moved to Germany. I used a transformer to connect my computer since in Germany their voltage is 240 and zapped my computer afterwards a...
If you are getting no power what so ever then it is your Power supply. After you replace your power suppy there is a red switch on the back of it. You can change it to 240.
Apr 15, 2010 | Gateway 300 X PC Desktop
Find HS doesn't work
Had sets will not beep if the battery is too low or drained of its charge. The power for the beep needs to come from a good battery charge, so if you are missing a hand set and its been out of the charge cradle for a long time, or the unit is more than 4 years old and the batteries wont charge anymore, then you can't use the find handset feature and probably can't use it to talk as well.
If you know that the batteries are good, then there are 2 other possibilities: the seek signal needs to be reset by unplugging power to the base unit for one minute and allowing the circuits to reset themselves, or the seek button is not making good contact inside and this would require someone with knowledge to open the base unit and clean or repair the button contacts. Finally, many hans sets have an on/off/standby feature. If the handset is in off position, the it isthe same as if you removed the battery and it will never beep; it must be on standby.
Oct 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
Hans-G Monitor monitor clicks will not power up
Sounds like capicitor could be faulty, shouldn't be that difficult or expensive to replace. What will cost you more is the labour so depends how expensive they are on that, if it's not too much then yeah it's worth fixing just ask for a quote first.
Aug 24, 2009 | Computers & Internet
I need Braun electronic food processor instruction manual (500 watt type 4262 - made in Germany
Manuals are available from Braun.
UK English:
http://www.service.braun.com/line/HH/H4262/H4262_2_GB.pdf
Auf Deutsch:
http://www.service.braun.com/line/HH/H4262/H4262_1_D.pdf
Thank you for asking here. Please take a moment to rate this solution if it has been helpful. Danke!
Mar 12, 2009 | Braun Food Processors
Wheelalignment
Check out Chilton.com or Haynes.com for your Model. These are Repair Books for Vehicles and they Really Help with EVERY Repair that you may Need to Do. Please Rate My Response! Thanks!
Feb 01, 2009 | 2001 Lincoln Town Car
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
ViewSonic N3000W 30 in. HD-Ready LCD Television Logo
187 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
