Question about Canon BJC 80 InkJet Printer
BJC -85 Setup Software wil not download to Vista...not compatable.....What can be done to se the Printer/Scanner on my computer with Vista.
    President:
  • 1,902 Answers
As the link (http://www.usa.canon.com/consumer/controller?act=OSCompatibilitySupportAct&keycode=vistadr&fcategoryid=230&modelid=6620) in Mike's solution states, "Driver included with OS. Download not required.", i.e. Vista comes with a driver for the BJC-85 so you don't need to download one. I've just connected my BJC-85 to my new Vista machine and the printer was detected and drivers loaded automatically.
Posted on Feb 18, 2009
Canon bjc 85 is not available in W7; drivers are not updated
This printer is fully compatible with Windows 7. So once the printer is connected to the computer just turn it on and windows 7 inbuilt driver agent will download the compatible driver for this printer. In short this printer is Plug & Play qualified.
Thanks,
Amar
Jul 20, 2011 | Canon BJC-85 InkJet Printer
Can I make this work with vista? Also, the scanner attachment?
Sorry, that printer is not supported by Vista, as far as I can tell there is no way to make it work. So sorry about that.
Sep 09, 2010 | Canon BJC-85 InkJet Printer
Will a bjc-85 work with vista?
The immediate response is that there is no Vista driver available for this printer from Canon.
However, that is not the end. Check the Vista printers and see if the driver is already built into Vista or Vista may supply a generic driver for older models of printers.
For a definite answer, you might want to call the Canon Support Center and get the Canon answer on this.
Don
Nov 25, 2009 | Canon BJC-85 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Bjc 85 vista driver???
Canon does not list a driver for Vista. You can see this at Cannon's web link here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=6620
& why here.
There is one other way to get a driver for vista. (Maybe). Microsoft has a program that you install. It scans your PC (make sure your printer is turned on)!
It checks your PC to see if it can run Vista. (even though you have it installed).
It also will show you at the end what driver software you need for vista. Including your printer & will give you a link to download the proper driver.
You have nothing to loose.
Once the vista program has finished & you download any missing drivers, just delete the program from Add/Remove programs in your control panel. Microsoft's Vista checker program link. Windows Vista Upgrade Advisor.
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
Good Luck.
Mike
Mar 25, 2008 | Canon BJC-85 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
187 people viewed this question
old marine
old marine
