Question about Sony CDX-M770 CD Player
Sony CDX L450, No sound from radio
The CD parts of the unit work correctly. Have swapped for another Radio, which also works correctly. Have used the re-set button but still no sound from radio. Any help much appeciated
  • 1 more comment
  • Wagomatic Feb 19, 2009
    blueextc3221:
    Unit has previously worked perfectly in this vehicle which is a Nissan Micra.
    Thanks for your interest.
  • serviceonema Apr 15, 2009
    I have the same problem with a sony c5005. Cd player works and sounds great but no sound when playing the radio. Confused?????
  • blueextc3221
    blueextc3221 May 11, 2010
    Was this radio a new install or has it worked before in this vehicle??
    What car is it in? Do you have "premium" factory sound system?
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: installing a sony cd/radio (CDX-GT222)
Sounds like a possible ground issue. Check your ground (very important). Also try running the red wire to a keyed source i.e. from fuse block. Then run the yellow to a constant 12v source i.e.battery.
Posted on Jun 30, 2009
SOURCE: my sony cdx 4000r is not picking up radio signals
sony cdx4000r not working correctly plays cd s inconsistently radio not playing ariel in place
Posted on Dec 07, 2009
SOURCE: How to change time on Sony cdx-gt430ip
how do i get the desplay to show so i can see what song is on and the volume
Posted on Mar 24, 2010
SOURCE: Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
i have the same problem, it was a factory fit and the garage checked it and all the connections were ok, it appears to be a fault with the receiver.the radio is just 3 years old.
Posted on Mar 25, 2010
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
Fitting radio to isuzu trooper 93 without
YOU WILL HAVE TO REMOVE SPEAKER AND LOOK AT THE COLOR OF THE WIRES AND MATCH THEM THEN FIND 12V FOR THE POWER AND METAL OF THE CAR FOR GROUND THAT IT
Aug 26, 2009 | Sony Car Audio & Video
My sony cdx 4000r is not picking up radio signals
Feb 19, 2009 | Sony CDX-4000X CD Player
No sound from cd but stereo works no problem
Feb 16, 2009 | Sony CDX-CA700X CD Player
Radio audio working but no audio from CD. Shows cd playing but no
:) swap your blue with your blue/wht or vice versa.. (behind the radio) this WILL fix your problem..
Jan 27, 2009 | Sony CDX-CA850X CD Player
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Sony CDX-GT310. Installed by Circuit City about 15 months ago. CD works fine. No sound from radio (both AM & FM). I've manually tuned through the range of stations with no reception. Checked...
Called a shop in VA and their opinion was that the tuner section of the unit failed. Cost of the part, $80. Then, labor and shipping. I can buy the new model (GT320) for about $95. I opted for buying a new unit.
Aug 11, 2008 | Sony CDX-GT310 CD Player
Sony CDX-M770 CD Player Logo
1,159 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
