Question about ViewSonic PJ860 Multimedia Projector
Double imaging I have a PJ860 at our church and it has a double image. The blue and yellow are out of line. There is thin blue stripe on the right and a wide yellow stripe. How can i correct this. J.R.
Exact same problem.. please email me if you find out the fix..
frmeek@yahoo.com
Posted on Apr 09, 2011
Wide gray bar with thin green, yellow, pink and blue stripes appears when tv is on.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 17, 2015 | Televison & Video
My toshiba 57H82 tv has double image blue and yellow
This is a known issue with the model that you have listed. The repair kit is here: http://www.tvrepairkits.com/xcart/57h82/ You should be able to solder, the kit comes with diagrams, photos, parts and support.
Mar 07, 2014 | Televison & Video
My Viewsonic PJ860 projector (aka Hitachi CP-S860W) has developed a condition in which there is a yellow vertical stripe down the right edge of the screen and a blue vertical stripe down the left side of...
It does sound like this is an alignment problem of the blue LCD or a problem on the main board controlling it. I am not sure if this is a field adjustable unit. A call to the authorized service center should provide that answer.
Aug 11, 2010 | Hitachi CP860960LAMP Projector Lamp for...
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Getting double image in colors
this is a lost of convegence power. first check to see if you have the convergence option in setup menu. if you do not then i suggest you read the fl231 problem in the tips and trick section. otherwise there a good chance u would have to replace convergence power supply board
Mar 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Wireing pioneer deh-p3500
Here is a wire diagram. I belive that is not a yellow with white stripe wire. I think it is a solid yellow wire that came off a pair of wires that is wher you get the white stripe.
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50148installation_manual_DEH-P3500_20021241433264130.pdf
Sorry that is all that I can think of the yellow wire. It does not show one in the wire diagrame. Good luck
Dec 17, 2008 | Pioneer DEH-P3500 CD Player
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Double image, blue and yellow images
convergence ic are going or have loose connection in the convergence amp ic area.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 15, 2008 | Hitachi 43FDX01B TV
Image Retention
burn in is not supposed to occur on an lcd tv, however I have an lcd from Proview that leaves images on the polymer layer the white horizontal address bar is the most prominent. if I leave the monitor off for about 3 days the images disappear, this may or may not help you, if Samsung has created a ticket on this issue you may well receive a prepaid shipping label to return the tv for repair.
Jan 10, 2008 | Samsung LN-S4051D 40 in. LCD Television
ViewSonic PJ860 Multimedia Projector Logo
597 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
