Question about Toshiba Satellite A105 Notebook
Cant get any power to run through my laptop
I have a toshiba L350D - 131 system unit, every time i try to turn it on it seems like there is no power going through it , it knockes off immediately, it is fully charged and even with it plugged in i still cant get anything. Thank You ,,, Tina
  • 298 Answers
Tyr this:
Gently remove and clean (with a pencil eraser) and reinstall your memory, then try again.
For you non-techies, it is very easy to hose a perfectly good laptop by NOT fully releasing the side-latches (some metal, some plastic) BEFORE gently lifting the RAM up 1/4", away from the pin/contact seating area, and OUT of the sockets. Actually, if you do it right and do not physically touch the face, sides or corners of the RAM when you use your Left and Right thumbnails to 'tease' the latches away from the sides of the RAM, it will POP out all by itself. cant get any power to run through my laptop - smile1.gif
Now... putting new RAM in is REALLY easy and does not require any force or pressure at all. Look at the socket and the RAM and orient your RAM so the slot in it (the RAM) and the raised portion of plastic in the contact seating area line up. If it is OBVIOUSLY not, flip the RAM over and check again. If it still will not, or can not line up... it is the wrong type RAM for your machine. Take it back. Do not try to 'make it fit' ;-)
Once you have RAM oriented so it WILL slot in, take the RAM between your index fingers and thumbs so the contacts are facing AWAY from you and hold firmly by putting the tips of your fingers into the holes on the sides of the RAM, ease the RAM into the socket and seating area, wiggle a bit side to side and seat in snugly, then maintaining the hold with your 2 Thumbs, tease the latches away from the socket edges with your fingernails (under the edges of the new RAM) so they both clear the sides of that RAM, then gently press down a bit further with your thumbs until the RAM face is below the latches and finally release the latches making sure BOTH are now above the RAM face. Done.
Don't FORCE... EVER ;-)
Hope this helps!
Posted on Apr 08, 2009
Where is cmos batterie on L350d
attached to the mother board you have to remove the case.
Jul 09, 2014 | Toshiba Satellite L350D PC Notebook
I turned on my laptop (toshiba satellite L350/L350D) a notification message appeared saying initialisation process had failed. It then turned the laptop off automatically. I then turned it back on, there...
You can turn it off by holding the power button for a few seconds till it turns off or if that does not work remove the battery.
thanks for using FixYa
Jul 01, 2011 | Toshiba Computers & Internet
My touchpad and cursor are not working can you tell me what the problem is i have a toshiba satelite l350d
have you tried an external usb mouse to see if it works?
it is possible that your touchpad is just turned off usually there is a switch near the touchpad where you can turn it on and off
May 12, 2011 | Toshiba Satelite 2405-S201 Notebook
Hello, Who can help me find out what's the problem with my Toshiba L350D laptop? The laptop doesn't start anymore. No lights switch on when connecting charger and pressing power. I checked the charger, the...
Is the power adapter putting out ~18 volts?
If so, the DC-in jack on the motherboard could be bad, but you say you checked that.. It can be replaced if you're good with a soldering iron.
Otherwise, I'd say you're looking at a replacement motherboard.
Apr 02, 2011 | Toshiba Computers & Internet
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Is there a reset button for toshiba L350D
Of course if you have your restore cds, you can revert to factory setting.
Cheers.
Aug 18, 2009 | Computers & Internet
Toshiba L350D Screen Loss
you may plug off remote monitor power on to see carefully is there normal dark picture on your lcd screen,
!) lcd dark but there is pcture on the screen, it means the back lights inverter damage(which in the lcd lid and downside of lcd panel), or lamp damage (in the lcd panel), have to replace new parts
2) no any picture and dark panel, you may check lcd signal cable plugs are right seat in the sockets (which located between the back of lcd panel and motherboard), also check the inverter cable same thing (it merges in LCD cable) . it is better replace a new cable (most cases are cable disconnection somewhere)
is this helpful please feedback when you checked, iwill tell you what you can do next, thanks
Feb 15, 2009 | Toshiba Satellite Pro L300D-EZ1002X...
Toshiba Satellite A105 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
