Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Samsung SR-L3928B - The "Super" light & buzzer comes
The "super" sign & sometimes the "vac" sign comes on for extended periods of times which is frustrating as the buzzer also constantly goes.
If I turn the fridge off for a short period of time, when it's switched back on it's fine until it seems to get back to the set temps & once again the "super" light goes on & off repeatedly.
Q) Do you know how to override the buzzer in the short term?
  • Anonymous May 23, 2009
    IF ANYONE knows the answer please help, i cant believe how many posts there are about this model of fridge and knowone seems to know what to do? did everyone just get new fridges? or did it stop itself? AHHHHHHHHHRRRRRGHHHH annoyed
5 Suggested Answers
dcp2
  • 63 Answers
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Posted on Jan 28, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
SOURCE: samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Posted on Sep 19, 2010
  • 117 Answers
SOURCE: SAMSUNG SR L3928B FRIDGE/FREEZER KEEPS
samsung fridge freezer problem">
Posted on Jan 16, 2011
Whirlpool super capacity 465, the over periodically doesn't light, need to restart the process multiple times, but then sometimes it works fine????? I'm puzzled
Hi Jim, when you get problems that occur periodically, then you have the beginning of things to come. Go ahead and have the board replaced and be done with it. Next thing that will happen will be that it will shut off while you are cooking something. Good luck.
Dec 15, 2014 | Whirlpool Ovens
Sanyo, super showerwave, microwave has quit working. Clock counts down, lights all come on, but no microwaves nor does the plate spin...any ideas?
Hi William,
The secondary interlock switch is bad. You need an ohm meter to verify that the switch is not 'closing' electrically. Opening the door when the microwave is running is the primary cause of this switch's failure. The secondary cause of this failure is from constantly running the unit for extended periods of time, usually more than ten minutes or more. Be careful..
Oct 22, 2013 | Microwave Ovens
Will the wheels from a 2000 Harley-Davidson FXDX Dyna Super Glide Sport fit on a 1999 Harley-Davidson FXDX Dyna Super Glide Sport both have dual disc brakes on front?
Check to see if they both have the same diameter axle. Harley went from a 7/8 inch diameter axle to a 1 inch diameter axle sometime around that time period.
Nov 15, 2009 | 2000 Harley Davidson FXDX Dyna Super Glide...
My 2000 f-350 fords ABS light first flikers after start-up then stays on for a period of time. Then goes out and comes back on and stays on.
The only thing you can really do on your own is pull the wheels off and check for any obvious signs of wear or damage to sensors and circuits. Otherwise, the module will have to be scanned to pull codes for further diagnosis.
Aug 12, 2009 | 2000 Ford F350 Super Duty Super Cab
Turn off buzzer
some models have a buzzer in control panel which can be unpluged wire sealed off ather built into time and can not be turned offf good luck
Mar 04, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Refrigerators Logo
126 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
