Question about Microsoft Xbox 360 Console
Xbox360 elite red light blinks and says error
What can I do about this.Does it mean It wont work anymore?
When I turn it own the light blinks red and it comes up error.What can I do?is this bad?
  • zexster May 11, 2010
    what red lights exactly are on and what error code are being produced?
  • 132 Answers
Yes, it needs to be sent into microsoft for repair.
Posted on Feb 18, 2009
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
My xbox is not reading disks but it dont have red
THIS IS A COMMON PROBLEM TRY UNPLUGGING YOUR CONSOLE AND PLUGGING IT BACK IN IF THAT DOESN'T WORK TRY CLEANING THE DISK READER THAT USUALLY WORKS FOR ME.
Aug 01, 2010 | Microsoft Xbox 360 Elite Console - Black
I have xbox360 elite modd.mfd 2007-10-16.now it shows e73.
it was a bad idea modding your xbox because in order to do so they have to remove a special chip or rewire so the chip is skipped.this chip stopped your h77 turner lap from over heating which is what has happened causing it to leak.you need a new UNMODDED xbox oh and whatch that liquid it,s highly acidic
May 15, 2010 | Microsoft Xbox 360 Elite Console - Black
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
My xbox elite has one blinking red lightand wont load any games it just says system error
You need to have the motherboard fixed, do to this you need to take the xbox360 apart then reflow the board. (MOST xbox360 errors are fixed this way)
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually used the same method to fix over 450 Xbox360 units with no problems at all, barring a few (but i have done nearly 500 so you expect a few problems along the way), you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
Jan 03, 2010 | Microsoft Xbox 360 Elite Console - Black
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
One Red Light in cpntroller number 4
Steve, what error code are you getting? Go here and find out what your error code means. http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Nov 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Mike Neath
Mike Neath
Jonathon summesfield
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
