Question about HP PSC 1315 All-In-One InkJet Printer
HAS BEEN WORKING GREAT. YESTERDAY IT DECIDED TO
HAS BEEN WORKING GREAT. YESTERDAY IT DECIDED TO QUIT PRINTING AND 1st SHOWED A MESSAGE "PAPER JAM". NOW IT SAYS "READY" BUT STILL WILL NOT PRINT. I HAVE INK AND CHECKED ALL THE BASIC THINGS...CONNECTED, PLUGGED IN, ETC... PLEASE HELP FAYE
FHUMMELL@BELLSOUTH.NET
    Scholar:
  • 77 Answers
Unplug the usb from the back of the printer. shut down the computer.
Make a copy by placing something on the scanner glass on top and pressing copy.
if it copies that means the hardware is okay.
reconnect the usb and reboot the pc. it would start printing any spooled up print jobs that got jammed when the paper got jammed.
if that dont work look at the bottom right and see if there is a printer icon at the bottom right. if there is double click on it and cancel all pending jobs.
reboot
if the copying dont work that means the paperjam killed the printer and you need a new one.
Cheers
rate if you got a fix . if not you know what happened.
Posted on Feb 18, 2009
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
I keep getting paper jam messages when there is no paper jam.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 23, 2009 | HP Photosmart C4180 All-In-One InkJet...
P2015dn paper stops in the through-output path with approx one-half to one inch of paper projecting. Jam indicator lights. Removing paper shows printing has completed over full length of paper.
please, gradually pull out the paper, off your printer and clear the scheduled print jobs through control pane-printers and faxes-select your printer to open then select all the jobs in it and cancel/delet, please before you on and start using make sure the papers in the feeder are aligned and fits the tray i mean set the tray according to the size of the paper, one minutes u can now on and start printing it will work 100% i use the same printer.
Jul 19, 2009 | HP LaserJet P2015 Printer
E3 message
paper sensor not working or sensor need to service
Apr 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print. showing 3e as the fault
someone replied to my problem, i tried it and its fixed 1st time, also seems to have worked for lots of others.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. Let me know how you get on, from Garty
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp 160
HI this is happening to me right now too-- try this-- I'm not sure if it's going to work-- but it's worth a shot.
On your computer, go to a print menu to print a document.
click on properties
go to maintenance tab
try the quiet/sleep mode
also, try going to custom and slow down the printing allowing for a little extra dry time.
reason I suggest it: my printer is doing the same, it's almost like the auto sheet feeder (only on the right side--why paper is grabbing weird) is grabbing too quickly. When in sleep mode, it seems to slow it down a little. I've also been printing 1 page at a time. I'm not saying this is a permanent fix, but at $50 for a pack of ink-- hopefully if you can't fix it-- it can get you to use up the last of the ink you have incase you decide to get a new printer.
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Pixma mp160 error message
Ok, my machine was also showing E3, and would NOT go away. My solution: turn the machine off, feed a piece of thick cardstock into the paper feed.Turn the machine on, let the machine take the paper almost all the way in, then pull it back all the way out against the feed. My E3 disappeared and has not yet returned!! Hope this helps David
Nov 26, 2007 | Canon PIXMA MP160 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
66 people viewed this question
Seeker5211
Seeker5211
