Question about Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX F511 wont' send or receive
This has to be the phone line? analog line?
Anything else?
  • Anonymous Mar 19, 2009
    We have the same problem with our Panasonic KX FL511. It won't send or receive a fax. We do have a dial tone and it is plugged into the LINE port in the back.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
If you cannot send or recieve. First make sure you have a dial tone at the jacj in the wall if you cannot hear it on the handset of the fax plug a phone into it and make sure.
Second make sure you have the line from the wall plugged into the jack on th machine that says LINE. Most machines have three jacks Phone handset and LINE Make sure you are in the LINE jack.
Hope this helps
Posted on Mar 14, 2009
Some analog line in not working on kx tda 200
have you tested the same line directly with an analog phone?Is it working?
Oct 09, 2012 | Panasonic Kx-tda0196 Remote Card For...
Will a panasonic KX-T7636 work with my ta824?
No. An 824 is analog and the 76xx is digital that works only on the TDA/TDE/NCP systems.
Older analog phones (70xx,71xx,73xx and 75xx) will work, and possibly some of the old 616 and 1232 sets, as well as a 308xx 3-line set.
Carl
Jul 22, 2011 | Panasonic KX-T7731 Corded Phone
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
I used to have the Panasonic KX-T7630 system in the office building we sold. I no longer have the capability of setting the entire system up - is there a way to use the phone as just a regular desk phone...
The KX-T7630 is a proprietary digital phone that will only work on panasonic phone systems. You need an analog phone if you are going to connect it directly to an outside telephone line.
Jan 19, 2011 | Panasonic KX-T7630 Corded Phone
I have two lines on my Panasonic KX-T7731 I would like the second line to be a completely different ring than the first line
Not possible. A Panasonic Analog PITS phone has only one ring sound and all CO rings match.
The TD series and 74xx phones were the first phones to have 8 ring tones. The TDA series has 30 different tones. Prices are fairly competitive for upgrading.
Dec 14, 2010 | Panasonic KX-T7731 Corded Phone
Two phonelines no longer accessible. Using Panasonic KX-T7730 with a Panasonic KX-TES824 system. Lines were working fine and have now disappeared. They don't ring in and I can't ring out on them. ...
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Oct 09, 2009 | Panasonic KX-T7730 Corded Phone
Want to connect fax machine to pc
The KX-FM131BX, KX-FM131CX and KX-FM131AL do not connect directly to a computer. They only have RJ-11 connections (to the phone line (line in) for all models and to another phone or answering machine (in some cases).
To send and receive faxes with a computer, you need some sort of USB or network port on the machine. Brother has some that may fit your needs: http://www.brother-usa.com/Fax/ModelDetail/2/FAX2840/Overview is one of their lower end models.
I hope this helps.
Dec 06, 2017 | Panasonic KX-FM131 Fax
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Analog to Digital Phone Service
Nope this machine needs a dedicated analog fax line it does not work in a digital telephone system.But if you are in a very small office with a few staff. you can get your telephone people to tap off a line off the demarcation block that comes into your telephone room for your fax.
Aug 02, 2007 | Panasonic KX-FP101 Plain Paper Thermal Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
170 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
