Question about Kenmore 24 in. 15149 Built-in Dishwasher
Dishwasher leaks out of the bottom and does not complete empty?
    Genius:
  • 2,920 Answers
You have a bad bottom seal
Posted on Feb 18, 2009
Will not empty completely. If I jam a sponge under the water level float, it WILL empty completely.
Good Afternoon Paul, thanks for your post!
Based off the information you have provided your Frigidaire dishwasher will not drain out completely. It is not uncommon for there to be some water left inside the bottom of your tub. I would recommend checking you filter to make sure that it is clean. The filter is located under the bottom rack in the center of the tub. Once you have removed that and cleaned it out you may see water less in the bottom of it. I hope this information is helpful to you. -Matt
May 25, 2015 | Frigidaire Dishwashers
Water leaking from bottom of dishwasher and sometimes not emptying inside dishwasher
it could be leak from the drain hose or any other hose like water flow hose, or water level (pressure switch ) hose , check also that the unit does not make over flow.
A.refaei@eajb.com.sa
Nov 11, 2013 | Hoover 24 in. DT999 Free-Standing...
Dishwasher leaks
Hello - Since you have previously replaced the bottom gasket and issue continues I suggest contacting a professional to move forward accurately. The leak could possibly be coming from the drain motor/pump or a loose hose connection located underneath.
Oct 03, 2012 | Frigidaire Professional Series 24 in....
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
My doshwasher is not draining all the water it
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Jan 12, 2010 | GE Profile PDW8400J Built-in Dishwasher
Maytag series 100 dishwasher not completely emptying after cycle
I am having trouble with water not emptying out of dishwasher completely help
Jan 07, 2010 | Maytag Dishwashers
Dishwasher is not completing the cycle, and water remains in the tub. I've cleaned the filter and that doesn't seem to solve the problem.
check you float switch at the back to see if it is sticking ,and it should always have at least an inch of water in it to keep the motor seal wet or it will dry up and leak creating another problem
Dec 25, 2009 | Dishwashers
Dishwasher fails to empty completely
make sure you don't block either sink with food as they share the same drain. Also check to make sure the hose between the washer and the sink is clear and not blocked with food/gunk.
Apr 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Kenmore 24 in. 15149 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
