Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The agitator does not work on the Stylemaster 4213631 washing machine. I know there is a part that can be replaced. Can you point me in the right direction. thanks
  • roydiane Feb 24, 2009
    the agitator does not work on the Ultimate Care II
  • Whirlpool Master
  • 3,361 Answers
Pop the top cover off the agitator to access the 4 agitator dogs.
They must be replaced.
Posted on Feb 22, 2009
Admiral stylemaster 4213343
Before you buy an agitator. Check the dogs that catch and cause the agitation motion. They cost 50 cents a piece and usually there aer five. Go on youtube and look for replacing dogears in washing machine agitator. Idid and thats all it was $1.00 2 dog ears wore out causing the agitator to slip. It took 30 min to fix. Hope this helps. The dogears get wore to round and will not hold! Brian Thompson
Sep 03, 2014 | Admiral Washing Machines
I have a Kenmore model stylemaster 909610. It fills normally, but doesn't agitate properly, it moves, but barely, no odd noises or anything, just barely agitates and the clothes don't move it's so weak....
If you can move the agitator in both directions, you may just have some bad agitator dogs. They are located under the dispenser cap, below another cap and remove a 7/16 bolt to replace.
Jul 01, 2014 | Washing Machines
Problem with a Lady Kenmore Model 902202
You might as well go ahead and replace the machine, the cost to repair this problem is going to shock you.
Jun 25, 2017 | Kenmore Washing Machines
Kenmore stylemaster 909964 80 series. will not agitate or spin. please help
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 11, 2010 | Kenmore Washing Machines
Whirlpool washer stylemaster 4213532 won't spin, replaced actuator, still won't spin. Pumps water and agitates.
check the connection of the plug if have power.check the motor should be 6ohms reading of motor windings
Mar 06, 2010 | Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Sep 22, 2009 | Whirlpool Washing Machines
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
Jan 22, 2008 | Whirlpool LSR6232J Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
903 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
