Question about Denon DP-47F Turntable
Denon DP-47f tonearm quickly skates across the platter.
After reassembling my DP-47f according to the service manual, when I press the start button, the platter rotates but the tonearm quickly skates across the platter right to left and then back again. It repeats this motion continuously so it keeps bouncing right to left until the stop button is pressed.
Thank you in advance for any help.
5 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Denon DP-47F
You might have a bad cue motor/ass'y. Did you buy this new, or used? Are you the original owner? Did this just start happening? Have you done anything different (moved the unit, cleaned it, etc) to the unit?
If the cue ass'y is bad, then that would require professional servicing.
- TWEAK AV LAB
Posted on Nov 26, 2007
maklean
  • 1665 Answers
SOURCE: Denon DP52F tonearm tube is turning freely
You must raise top cover to have acces to arm support shaft and tighten holding nut.
Posted on Sep 14, 2008
  • 58 Answers
SOURCE: platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Posted on Sep 26, 2008
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Apr 14, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a DENON DP-47F
At least 7 of them on eBay with cartridges. Search "DENON DP-47F headshell" and check 'inlcude description' box.
http://cgi.ebay.com/NEW-TURNTABLE-HEADSHELL-CARTRIDGE-DIAMOND-NEEDLE-/350438023145?pt=LH_DefaultDomain_0&hash=item5197bbdfe9
http://cgi.ebay.com/NEW-TURNTABLE-HEADSHELL-CARTRIDGE-DIAMOND-NEEDLE-/350438814767?pt=LH_DefaultDomain_0&hash=item5197c7f42f
Posted on Apr 26, 2011
How do i find a turntable cartridge technics headshell SL-BD22
The SL-BD22 turntable's tonearm does not have a headshell. It takes a P-mount (otherwise known as a T4P) cartridge which plugs directly into the end of the arm.
May 21, 2014 | Denon DP-47F Turntable
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
My denon 26-f turntable stylus arm lifts about 2 minutes before end of record. how can this be adjusted on the turntable?
Hi Richard, at the base of the tonearm look for a rubber grommet. Under it you will find a screw. Adjust clockwise slightly to make the tonearm lift further along. Fine tune antil sorted. If the adjustment is not at tonearm base remove the rubber platter mat. If the platter has an access hole in it rotate platter so the hole is near the tonearm and look for scew to adjust. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Apr 14, 2011 | Denon DP-47F Turntable
The arm just slides across the record.
The link for this model's manual is a dead-end at the Panasonic website. I lodged an email complaint.
If the tonearms balance and anti-skate are set properly it should track correctly.
When you lower the tonearm does it actuallu drop onto the platter or does it seem to hover? Look at the stylus to make sure a dustball hasn't clogged the tip.
Jan 19, 2011 | Technics SL-BD20D Turntable
Platter won't turn
Souds like the belt has snapped or slipped off. Lift the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Nov 20, 2010 | Denon DP-47F Turntable
Platter turns slow
Best regards,
Andre
Apr 06, 2008 | Denon DP-47F Turntable
The arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Apr 01, 2008 | Denon DP-47F Turntable
Denon DP-47F
- TWEAK AV LAB
Nov 25, 2007 | Denon DP-47F Turntable
Denon DP-47F Turntable Logo
216 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
