Question about Magellan Maestro 4250 GPS
Magellan just stays on Magellan blue screen - Magellan Maestro 4250 GPS
  • 3 more comments
  • anh_chutieu Feb 21, 2009
    Magellan just stays on Magellan blue screen" problem
  • ant_fondeur Mar 10, 2009
    it just stay on the very first blue screen when you turn it On !! and i press reset and just do the same !!
  • JimMcN Mar 15, 2009
    My Maestro 4250 gets to the blue Magellan screen and stays there also. Magellan said they do not support out of warranty products.
  • ricky lee Mar 28, 2009
    Same problem, brand new Mestro 2450 powers up and stays on the blue screen. It worked fine for about 2 weeks, and fine until I was in the middle of downloading the new 08/09 maps, when it froze and now stays in this "blue screen of death".
  • ricky lee May 11, 2010
    Typo, meant Maestro 4250.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Other than replacing the unit, there appears to be no "fix".
Posted on Mar 30, 2009
SOURCE:
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 | GPS
My magellan triton 1500 gps units 'blue-screens' my pc using windows 7 os. How can this be rectified?
The BSOD is caused by the wrong Magellan Drivers. Please download and install VantagePoint 1.94 to solve your problem
May 20, 2010 | GPS
Screen stays on the blue magellan screen and won't reset
  • Try to press and hold the reset botton for 15 seconds if that will not work try to press the power botton for at least 10 seconds. If these two will not work, call the tech support of magellan and check if its still under warranty so they can fix it for free. But if its not under warranty try to trade it in for free and they will give you a cheaper price.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Feb 14, 2010 | Magellan Maestro 4250 GPS
Have a 4040 maestro magellan will not get off the magellan screen
if this just happened, and you have not tried to update it (sometimes the update causes this) then power the 4040 on and once it finished loading to the blue screen, using a paper clip, depress the reset switch on the left side and let it restart (little pinhole on the left side under the usb port)
if you need further help, just reply to this post.
bill
Jan 03, 2010 | Magellan Maestro 4040 GPS Receiver
Hi, I have Magellan roadmate 3000t. When I turn it on, it shows Magellan blue screen and stays it forever. I tried to reset many times without success. Can you help me to solve this problem?
if you havent updated it yet, you can go here for the update for your model..just look up your model on the right side and download your update (you must register on magellangps.com to be able to download)
Jul 03, 2009 | Magellan RoadMate 3000T GPS Receiver
Magellan 4250 blue screen, not able to reset
This may mean that the GPS was formatted and there is no data on it. So basically, you can't do anything with it because all the maps and software were deleted.
May 31, 2009 | Magellan Maestro 4040 GPS Receiver
Blue screen with magellan logo , this is what I see after turn on my gps receiver, I tryed to push any button but anything change on the screen, to shut it off i have to use 'enter' ,'cancel' and power...
This is the boot screen, Remove the power connection, and reinsert while you press the "Cancel" button at the same time, if done correctly, your Roadmate should continue to boot and enter the user mode.
Mar 16, 2009 | Magellan RoadMate 700 GPS Receiver
Magellan Maestro 4250 GPS Logo
633 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
