Question about Canon imageRUNNER 210S Copier
Feeder not working, need spare part kit for Cannon copier ImageRUNNER 330S
    Scholar:
  • 93 Answers
I would try www.precisionroller.com or perhaps www.katun.com for aftermarket parts for the doc feeder.
If all else fails you can find your local Canon dealer and buy parts directly.
Hope this helps
TankMurdock
Posted on Apr 28, 2009
What does a hard drive cost for a cannon 330s
A new hard drive is about $100.00..... The problem is getting some one to flash the drive with the correct software. The copier is about ten years old or soo.
Jan 13, 2013 | Canon ImageRUNNER 330s Copier
Our cannon ir has the error code E002... what does that mean? The model is 330s. And how can we fix it? Thanking you in advance.
that is mean problem with thermistor.
you must replace a new.
position is inside near exit paper place.
May 18, 2011 | Canon ImageRUNNER 330s Copier
My Canon Imagerunner 330S feeder usually pulls multiple sheets at a time which stops the copier and requires me to pull the pages back out by force. This problem did not occur for the first several years...
This is usually a simple fix. Most common cause is simply a worn separation pad or roller. What model of document feeder is it? There should be a serial plate on the back of the feeder or under the bottom side down towards where the feeder mounts to the machine. If I get the model then I can list the parts you need. Also is the machine under a maintenance contract? If so then I would make them fix it. Especially if the parts required are available.
Thank You for using Fixya.
WheatlandServices
Jan 24, 2011 | Canon ImageRUNNER 330s Copier
Need steps in removing old toner from canon image runner 330S copier
open front cover, release developer lever at right,release feeder lever at down right corner,unscrew the centre screw at the top of the drum unit, slide out the drum unit, at the back of unit u will find a clear plastic cap remove it and empty the waste toner reverse all the process to place all togather.
Jan 04, 2011 | Canon ImageRUNNER 330s Copier
Hello, we bought a used imagerunner 330s. it has no network cable .. how to print?? where to even plug? is it only a copier or does it actually print also?
First of all does the copier have the optional printer kit in it? If it does, then you should look at the left side rear. You should see a cover about 10 inches long and that's where the ethernet plug should be. I believe pressing the print button should tell you if the option is installed.
Dec 07, 2010 | Canon ImageRUNNER 330s Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Imagerunner 330s id
remove all the ids you stored in the machine. even one id is left means it will ask for p/w.
Feb 18, 2009 | Canon ImageRUNNER 330s Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any...
check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Feb 09, 2009 | Canon ImageRUNNER 330s Copier
Canon imageRUNNER 210S Copier Logo
100 people viewed this question
old marine
old marine
