Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Flashing lights on Hotpoint FDW20P Dishwasher
I came home to find the bottom rotor of the machine had come unscrewed inside the machine it had however completed a wash' I then found that when I turned it on for another wash the prewash light came on, I could hear the water flow for a short time but not through the roters. the drain pump then started and both the prewash and rinse lights started to flash. If I set the machine to Normal wash the wash licht comes on and then the same sonario as above resulting in the water draining and the prewash and rinse lights flashing.
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Posted on Feb 19, 2009
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
Hotpoint BC1450 Light 2 normal flashes
Flashing lights, pump running even when turned off. Had to switch off at the socket. The vibration from the machine had managed to give a quarter turn to the appliance gate valve, the type with the little blue handle. I could see the indentation in the rear rubber panel on the back of the dishwasher. Unscrewed the little blue handle, pushed the machine back in and started working as normal. :)
Oct 07, 2012 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
How can I unscrew the drain outlet at the bottom front of my Hotpoint WT540? Our machine has completed a wash and drained, but isn't spinning. The door light flashes when I try and run a spin. I decided to...
Keep trying to unscrew it, as it should come right out for cleaning. A little water will come out too so put a small tray under the machine first.
Look at my other solutions, as for DOOR light flashing.
Apr 02, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Dec 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
FDW60 dishwasher
I've just (as of 10 minutes ago) had the same problem. I followed the advice given elsewhere in this forum and removed the bottom cover - water running out so needed a big towel to mop it up. I stood the machine upright and restarted it - no problem! it started straight away.
The question now is where is the water coming from? It seems there is obviously a leak somewhere and water is gathering in the undertray setting off the microswitch.
Oct 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
NOT WORKING FDW20p What does it mean
Hold the start key down and it should re-set . Please Rate This ! Thanx!!
Apr 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
FDW20P Error lights.
Hiya, i have the same problem. I am getting mine repaired on the 16th Next monday Booked an appointment with Hotpoint there coming to see and fix it. I will ask about the flashing lights and if you keep in contact i will let you know Ok"
Sep 20, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
382 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
