Question about Gateway MX6454 Notebook PC
Internet connection my gateway laptop is wireless and wont connect to the internet
  • blessed46 Feb 18, 2009
    How do you uninstall and reinstall TCP?
  • hdsportyem
    hdsportyem May 11, 2010
    Hi.. Can you see the router in windows? Perhaps uninstall and reinstall tcp-ip is the router using a ssid? most have security.. have tou set the encryption number correctly?
    Thanks
    jim
4 Suggested Answers
hothawk
  • 174 Answers
SOURCE: Wireless internet connection
First step - Enable your wireless hardware by switching it on some models have a separate switch or with the keyboard
Second step - Check your wireless zero configuration service under adminitration tools ->services is running or its managed by another software supplied along with your laptop - enable it. one only works at a time.
third step - go to your network connections choose wireless connection and right click properties double click on Internet protocol TCP/IP and see there is any IP manually inserted change it to automatically obtain IP address
Four step - Open your Internet Explorer and enjoy wireless internet.
Note. Some laptop required to create profiles prior to connect to wireless but from your post i hope your laptop is not one of them
Posted on Jul 08, 2008
tanvierahmed
  • 118 Answers
SOURCE: gateway laptop was connecting to internet wirelessly, not now
Check that if there is Static ip configured on your Lan-Card...
if yes.. then you need to configure the IP addresses manually for W-LAN as well.
One more thing; if Lan-card is not configured with static IP then
make sure your W-lan IP seting is on "obtain Ip automatically"
Here is the way to do this....
Click on the start orb to open a list of programs and content. The start menu has been replaced by the “start orb” which still gives you the same functionality as the start button from previous OS versions, but consumes less screen real estate.
Right click on “Network” and go to properties. That opens the “Network and Sharing Center” which is your central office for anything pertaining to (just as it says) networking or sharing resources.
On the left hand column you want to click on “Manage Network Connections.”
This opens the Network Connections Window which you will find familiar to Windows 2000/XP. It will list all of your NICs or Wireless Connections.
Right click and go to properties of the connection you would like to statically assign. You will now be prompted for an administrative password. This is part of Microsoft’s new User Account Control (UAC) which will help unauthorized changes to your systems.
Once you have authenticated you will see the properties of the selected network connection.
The properties screen is very similar to what you’ve seen in the past, but one thing you will likely notice is by default Windows Vista supports IPv6. If you’re on a corporate or government network that is running IPv6 you can fill in your IP information there.
Otherwise, you will select Internet Protocol Version 4 (IPv4) and click properties. Now you will be able to Choose the option "Obtain Ip adress automaticlay"
Close the Network Connections Window
Let me know if this helps.. Good luck...
regards,
Posted on Dec 04, 2008
acdr
  • 1913 Answers
SOURCE: ASUS PRO50G series laptop, wont connect to my wireless internet
pls tell me when u clik on connect wi fi what error come.
r u able to connect or not let me know please
Posted on Mar 23, 2009
I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
2.Right-click the Wireless Network Connection, and then click Properties.
3.On the Wireless Networks tab click Add.
4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
6.Click OK and your home network will be added to the list of preferred networks.
if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
Aug 25, 2010 | D-Link (DI-784) Wireless Router
Im trying to connect to a wireless network and it says it is connected but when i open the internet it does not work
check the configuration of your laptop. use another laptop to check the wireless configuration if its working in another laptop...check all possible setting of your laptop..make it fault all if needed
Jun 24, 2010 | Acer Aspire 5050-3242 Notebook
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
I am trying to connect a new laptop to my home network. The wireless connection indicates that it is connected to the internet, but i canno get to the internet. I have statically assigned an IP like...
Internet explorer... Under the address bar you should see "file, view edit,favorites, tools and help" click on tools, internet options and go to the connections tab. make sure you have nothing in the white box then click on LAN settings. I bet you have "proxy settings" checked. None of the boxes should be checked.
Oct 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Gateway laptop, can't connect to internet
Network controller in SouthBridge chip on motherboard needs REFLOW or replacement.
Basically board needs service.
Apr 02, 2009 | Computers & Internet
My wireless laptop gateway won't connect to my router again after going out of town using it at hotel and now it wont connect at home. it will connect on my job with no problem
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Feb 18, 2009 | Gateway MT3705 Notebook
Belkin wireless security
plug a laptop straight into the router with a cable. then open an internet browser and type in 192.168.0.1
type in the username and password. the default will be admin for username and password for password. then close the browser and unplug the cable. it might detect wireless internet after a few seconds. if it doesn't, it is possible that you have a PC set up as the internet gateway for the laptops or something, so when you introduce encryption the laptops can't get access. in which case you should go to your wireless icon on the laptop and click that and open the connection list. double click on the wap secured connection and try to connect. it should ask for a username and password, which you have secured the wireless encryption with. enter that and it should connect to the gateway.
dunno if this helps, good luck
chris
ziraffa@hotmail.com
Dec 10, 2008 | Belkin (F5D9230-4) Wireless Router...
Gateway MX6454 Notebook PC Logo
128 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
