Question about Epson Stylus C46 InkJet Printer
C90 belt hi,,im using my epson c90 for not more than a year now..but the yellow belt inside of it already loosen..is this replaceable? how much do you think will it cost me if im going to bring this in the computer repair shop?thank you very much for your favorable response...hope you could email me at dastinromana@yahoo.com bles
  • 353 Answers
Has the belt come off the drive pinion? If so, you will need to remove the printer top cover, loosen the drive motor screws, put the drive belt back on the pinion and re-tighten the drive motor screws. If this isn't the problem, find a technician who will look at it and give you a price for doing the job. It shouldn't be expensive, but maybe more than the printer is worth!
Posted on Feb 27, 2009
How can i install printer epson stylus c90?
Hi, Go to the epson website and click on support and drivers, downlaod the driver for your epson c90 and follow the on screen instructions. If you have to install the driver manually please post back. Thanks
Aug 10, 2011 | Office Equipment & Supplies
I have no installer for my epson stylus C90 printer
Here is the direct download link to your Epson C90. Just click the I Agree button and you're all set to download the driver:
http://download.ebz.epson.net/dsc/du/02/DriverDownloadInfo.do?LG2=EN&CN2=SG&CTI=4&PRN=Stylus%20C90&OSC=WS
I'd appreciate it if you tell me how this goes so I can suggest other solution if it doesn't help. Thank you for using FixYa.
Dec 10, 2010 | Computers & Internet
Replacement of ink
Hi,just go to the printers properties select maintainance select status monitor from there the procedure is self explanatory,try that.
Jun 15, 2009 | Epson Stylus C88 InkJet Photo Printer
Parts inside your printer are near the end of their service life.
if you put this in google ssc download it and this will reset your printer hope this helps
Feb 26, 2009 | Epson Office Equipment & Supplies
C90 epson printer "appears" Cannot be used error
1/ first of all please , don't forget change , date vacate , , date , please ( yes sir ) , ,
2/ begin , adjustment , will go up this window comes to , click already at , Accept ,
3/ , click already at , Perticular adjustment mode ,
4/ click at , Waste ink pad counter , to strip [ zone blue ] , then press , ok ,
5/ already will go up a window , Waste ink pad counter , click at , check , clip_image010.jpg
6/ press , ok ,
7 / click already at , lnitiailzation ,
8/ press , ok ,
9/ last step , press , ok , then close , then open again , only ( yes sir ) , ,
Dec 17, 2008 | Epson AcuLaser C900 Printer
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson c90
did you remove protective strip from cartridge
Jul 24, 2008 | Computers & Internet
I dont know how...
Unraqr the c90.rar file and copy the extraction to any folder on your hard disk (for future frequent use).
The following only works after refilling the cartridges or using a continuous ink system.
Note: This is for the Epson C90; there are a lot more printer specific resetters. Mine is Indonesian.
Note: This does NOT work if the system date is NOT set at July 15, 2007 !!
1. Set the system date to July 15, 2007.
2. Go to MY COMPUTER, open local disk C: then delete the ADJUSTMENT PROGRAM FOLDER (if present)
3. Close local disk
4. Click START, RUN, type REGEDIT
4. Open HKEY LOCAL MACHINE
5. Open Software folder
6. Open Epson folder
7. Delete PTSG folder (right click, remove=yes)
8. Open Epson C90 Resetter folder and start adjprog
9. Click ACCEPT button
10. Click SELECT button to go to port menu. Selected designated port number (USB ...)
11. Click the "Particular Adjustment Mode" button
12. Double click the "Waste Ink pad Counter"
13. Click the "Check" button
14. Click the "Initialization" button.
15. Turn of the printer and press "OK"
16. Turn on the printer and wait until the maintenance procedure has finished
17. Close the panels of the Adjustment program
18. Reset the date to the current date.
Note: Print these steps for future use.
Note: With a continuous ink system, make sure that the ink filling cable is not to tight; the print head with the attached ink
cabling must be able to freely move all the way to the left inside the printer. Also make sure that none of the ink tubes is squeezed tight by the black plastic clamps that are used to attach the system to the outside (front) of your C90. Place them so that the transparent cover stays slightly open.
Note: With a continuous ink system, be sure to use the "lock roller" on the ink system to close the ink supply when the printer is not in use; otherwise your ink evaporates.
Note: The continuous ink system is quite erratic in its signalling: when one of the colors is about 1/3 full on the Epson monitor, the printer might stop suddenly and display the cartridge X signal. Sometimes, with 2 colors X-ed, you have to do the procedure twice!
I don't know where you got the C90.rar download. You must have the following files:
AdjProg.exe
Apdadrv.dll
EditText.dat
StrGene.dll
If you don't have them all or miss some, pls e-mail me (hanshufkens@yahoo.com) and I'll sent them to you (attachment is about 2 MB)
Last: The C90 is a **** printer. After 4 months of use the paper adjustment goes to hell, so with printing you never know if printing will start before the paper is properly loaded. Might as well buy a new printer (NOT Epson!).
Jul 23, 2008 | Epson AcuLaser C900 Printer
Epson Stylus C46 InkJet Printer Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
