Question about E-Machines T1090 PC Desktop
PCI video card not working in XP, T1090 emachine
Looking at a T1090, it was a freebie hand me down to a friend and I'm trying to speed it up. I added some ram, a second HD and after reading some blogs had heard the integrated video slows down the machine. I put a old trident card in. It boots, splash screen comes up, then blanks out when the desktop should appear. Sounds like a XP driver is needed. Shows up in Device mangager. I move the monitor cable back to the on board video connector to pick up where the trident leaves off. I have read I need to disable onboard video, but don't see that option in the BIOS. I ran WinUpdate, and tried the upgrade driver option in DevMan, Xp seems to like the current driver, but it just doesn't work.
  • 1 more comment
  • tgilbo2 Feb 18, 2009
    Thanks for your reply eroutt, I had mentioned I read to do that, but did not see a disable feature for it in the BIOS. I do see where it lets me choose the default video adapter- PCI or AGP. The only thing I see for the integrated perpherals is power options for the modem and Lan. I considered a BIOS upgrade. I removed the floppy and used it's bay to securely mount the second hard drive, but I can still plug in the floppy to use for the BIOS flash- do you think that would help? I tried looking for things that a BIOS upgrade would enhance on that model but found no info.
    Thanks again--
    I can try that- my thinking is worst case scenario the card should work, maybe only 800x600 with few pixels, but it sould give me something. Card must be good if I get all the way to the splash screen. So you're thinking once windows starts, it's looking for the onboard video and if I disable that, it will look elswhere??
  • tgilbo2 Feb 19, 2009
    that worked perfectly- thank you for that suggestion- any other tricks for speeding that puppy up?
    Problem Solver:
  • 5 Answers
Have you disabled the on-board video, if not you will have a conflict between the 2
Posted on Feb 18, 2009
  • Eric Routt Feb 18, 2009
    U can go into device manager and disable on-board and turn off comp and install card and plug VGA cable in and if u have no pic restart comp and hit F8 and go Last Known Workin Config
Where do you plug in the adaptor on the e machine for wifi
Depends on what kind of Wireless Adapter you are using
There's the Wireless Adapter Card
Comes in three styles of connection,
1) PCI Wireless Adapter Card,
2) And PCI-Express x1 Wireless Adapter Card,
PCI-Express x4 style may be out there too.
(I've never bothered to look. I use the USB style)
A Wireless Adapter Card based on the PCI technology, goes in a PCI slot. Generally White in color, but NOT always,
A Wireless Adapter Card based on the PCI Express technology, is used in a PCI-Express x1 slot,
Top example is a PCI-Express x4 slot.
Moving down, next is a PCI-E x16 slot
Next, PCI-E x1 slot
Next is a PCI-E x16 slot,
and the last one at the bottom is a PCI slot.
Notice they are all Yellow.
Color of connector does NOT matter.
What the expansion slot is, does........
Also there is a USB Wireless Adapter,
This type of Wireless Adapter, plugs into any available USB port on the computer.
Front or back of an eMachines desktop computer, in any available USB port.
Any available open USB port, on an eMachines laptop.
(Or any computer manufacturer)
What is the model number of the eMachines Desktop PC?
Examples, T1090, T2460, W4685, D2246, etc.
I should be able to tell you what motherboard is used inside, and may have access to a link, to the Motherboard Manual.
Post back in a Comment.
Apr 14, 2013 | E-Machines eMachines Desktop PC
Looking to upgrade my Emachine W3118 Graphics Card Need Help!
Yes if you have a PCI slot your can purchase many video cards with TV-out and S-video out. Do not PCI confused with PCI-E though. Thank you
Oct 15, 2009 | E-Machines eMachines Desktop PC
I need to disable the onboard video card on the emachine t1090 but I don't have any video output
Enter the bios under onboard devices you see the the video adapter disable it there save and exit
Oct 07, 2009 | E-Machines T1090 PC Desktop
EMachine Video Card upgrade
Ok so are you getting video from the card? Look in system information and see what graphics hardware the computers says is installed. Are you replacing a video card or did you add a card to the system? If you are adding a card make sure that you change the settings in the BIOS to boot first on AGP/PCI-E express slot. Make sure that fast write settings and bus speed settings are compatible with your card. For example if you purchased a 8X AGP card and your computer only does 4X the card may not work. Double check that you are trying to install the correct drivers for your card and operating system.
Sep 12, 2009 | E-Machines eMachines Desktop PC
Wont load passed windows xp screen
Try holding down the "F-8" key when the emachines logo appears, see if you get a prompt for "safe mode". If you can get the system up and running in safe mode, shut it back down from the start menu. That should rewrite the boot sector and may clear the problem.
May 10, 2009 | Computers & Internet
A an Emachine T1090 with 128mb of RAM. System takes forever (10 minutes) to boot up. Once up and running it performs much better. Are there any known cures? Would adding RAM help?
Adding RAM would definitely help. What operating system are you running? You could run msconfig and try starting with a diagnostic startup. If the computer loads much more quickly, you could remove some of your startup items. Ask someone before removing anything though!
Jan 24, 2009 | E-Machines T1090 PC Desktop
High speed usb port in a emachine 350
That is really a question for them. Differetn system will support different devices. In most cases, adding a USB 2 card will work with almost any system that is not over a few years old.
Dec 28, 2008 | Koutech Systems Koutech I/O Future PU320...
Monitor doesn't work
Sounds like a bad video adapter. I'm assuming your emachines has an integrated video adapter. Put in a video card (with the power plug pulled out! Touch the bare metal frame of the computer with your hand before inserting the video card into the agp or pci slot Don't touch the motherboard). If you get video, you may or may not need to install drivers after that. XP has a lot of video drivers, but lacks quite a few of them, too.
Jul 30, 2008 | E-Machines eMachines Desktop PC
PCI socket on 4 yr old emachine
Here are the specs to your machine:
click the specs tab. It seems you have only PCI slots in thos machine, so you cannot use an AGP card (the other type you may have seen). Video cards are clearly marked PCI or AGP.
Does this machine not have a built in video port already? Or do you just want to upgrade?
Jun 30, 2008 | Nvidia Computers & Internet
E-Machines T1090 PC Desktop Logo
397 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
