Related Tags:
This problem should be removed because:
Problem with Hitachi 500GB 7200RPM 16MB BUFFER SERIAL ATA II/300, 3.5INCH, 8.8MS SEEK, DESKSTAR P7K50 500 GB Hard Drive
Can't format HDD
I've recently bought a new 500GB HDD, built it in my PC, turned it on and tried to format it to NTFS with the windows utility. To no avail...
When it reaches 100% I get a very self-explanatory error: "Format not completed." is all it says.
I then tried PartitionMagic 8.0, tried formatting the whole disk NTFS, also tried formatting only part of it, I got an error 514 or 517, and all that said was: "unknown error".
I then tried formatting FAT32, and got an error 11117. I have no clue to what this one means.
Anyway, I'm stuck here with a 500GB HDD I can't format, 've already been back to the store bought it, switched it, so it can't be the hardware...I've also been looking at other forums, there are people with the same problem, but no-one there posted a solution.
Thanks for the help already,
Yannick
Solutions (2)
The best partitioning is from windows xp setup disk , and also the best format .
Why get to format and loose all your files when you can backup your as many times as you can and keep them safe ?
I am using http://www.dmailer.com/dmailer-backup.html and i formatted my computer like 2 times in 1 year and it didn't taked more than 20 minutes to reinstal it and restore the backup
Hey, please try to diconnect and reconnect the CD/DVD drive and check if this works.. Some times installation is incomplete if the file skip during installation.....
well! in this case, I would suggest to contact the manufacturer of the Hard drive. This would be the best option to contact manufacturer website. Because these complicated issues can be resolved by them. Also.. I doubt tat whether the xp os supports 500gb hard drive.. If it is yes then the best option would be to contact the manufacturer
the best option would be to contact the manufacturer.. I doubt that whether xp os supports 500gb hard drive if yes then I suggest to contact manufacturer.
May I know what did you do manually to fix the problem?????
FreeAgent Drive cannot be Modified?
I just purchased a Seagate 500GB XHD. When I try to drag and drop to it, It says "FreeAgent Drive cannot be Modified". I am...
simpleDrive 160
I would like to know where to go to get the software to download and install to my Dell computer .
I can't transer file sizes more than 4 GB...
I can't transer file sizes more than 4 GB... What I've done to get around this is save my movies in multiple parts to make each file...
cannot copy more than 4gb file on a 500gb external...
cannot copy more than 4gb file on a 500gb external usb hard disk
Add Your Solution
NuLine 6" Buffer Model CS-106
NuLine 6" Buffer Model CS-106 - need user manual/instructions
i used sand paper to
i used sand paper to sand away burn mark on a bathroom couter top how do i get the scrartches out of the counter top
hitachi digger 200-2 serial no 147-60531
hitachi digger 200-2 serial no 147-60531 what years that digger
Hitachi Deskstar 500MB SATA 7200rpm not found
I have an external icybox usb harddrive enclosure and have been trying to install a Hitachi Deskstar 500MB SATA 7200rpm...
Fix-O-Meter
680
680 people viewed this problem
- 0 people are following this problem. Be the first!
Top Hitachi Hard Drive Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
