Question about Cobra 18 Wx St Ii Mobile Cb Radio
Mobile Cobra CB Squeels on other people's radios when I transmit.
I have been troubleshooting this problem for months...
I have mobile Cobra 18WX-ST-II CB Radio hooked up to a 4-foot Firestik no-ground-plane antenna. I get crystal-clear reception from people miles down the road, but when I transmit, people tell me to, "throw that CB out the window" because all it does it squeal like crazy. Plus, the TX transmit bar goes all the way into the red while transmitting.
I have the no-ground-plane antenna because my car is a 2005 Saturn Ion III, and is predominantly coverd in plastic. The antenna is mounted high on the trunk area of the driver's side, and it is insulated from the car. The coax runs through the trunk and along the floor of the inside of the cabin, up to the CB radio, which is hooked to the bottom of the dashboard of my car. The wire is not pinched in any way, nor is it cross. The connection is solid at both ends. I have tried tuning the end of the firestik, and I have tried grounding it directly to the negative terminal on the battery, even though it's a no-ground-plane necessary rig.
The CB Radio is power through the cigarette lighter with clean, solid connections.I am not picking up RF interference because I have tried the CB radio with the car shut off.
The CB is stock, the radio coax is unchanged, the antenna is unobstructed...
Please, for the love of God, can anyone give me some ideas? Do I perhaps need to find a way to ground the actual CB Radio metal box to the chassis? And if so, how? Could the position of the antenna be poor? Could I have not made solid ground connections even though it's a no-ground-plane rig?
Thank you.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Change your Mike out. Your AF chip and RF chip is the same chip. If the mike wire is broken and the ground is not releasing it squeals on transmitt. That is why your meter pegs put when you key the mike. Power has nothing to do with it nor does the type of antenna. These things are made so cheap these days all the components are daul purpose. Try this,,, unplug the mike while someone is talking. The speaker will stop working.... it lost it's ground for the AF side of the chip, so when you key the mike it does the same thing but turns it into a RF chip.
Posted on Aug 27, 2009
    Genius:
  • 1,139 Answers
Hello winfieldweth,
Have you tried measuring the power output of your radio? If you do, I bet you that the power output is over 4watts PEP. This could be caused by a component changing value over time. What I would suggest you do is to measure the power first to see if the power is over 4watts PEP and then proceed from there. I don't believe it's a grounding issue since the antenna being used is made for a no ground condition. Now if you are planning to use a ground type antenna, I would suggest that you not do that, only because just grounding the antenna will technically do no good, since when the say ground what they are talking about is a ground plane no just a grounding point.
Check your power and then we can start repairing this problem.
I hope this helps, keep me informed on the progress.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Mar 11, 2009
I have recently bought a new Cobra 29 LTD BT(new) from the USA not realising it was 27MHz? Does anyone know if you can get them changed to 26MHz? Or does anyone do it? I'm a truckie & would li
It is stuck on 27 by design and FCC rules--those almost never will go down to 26 and if did would require extensive retuning to receive and or transmit there----sell it if you need 26 and buy a Ranger or Galaxy instead.
May 16, 2012 | Cobra 29-LTD BT Mobile CB Radio w/...
Cx80, what does the code "rx" mean on the display
  • TX = Transmit. RX = Receive. Does your needle move when you key the mic? Does it modulate when you talk in the mic? Do you have an inline watt/SWR meter inline? What kind of a set up do you have? Mobile? Base? Get back to me if you want further help.
Regards, Tony
Oct 18, 2011 | Cobra 29 LTD CB Radio
I have cobra 29 mobile cb an every now an then it dies out . Power is on on noise I can key the mike an the needle don't move an can't here talking
May be a chip inside there that controls receive and transmit. Its about a 16 pin chip. If its getting hot. you may need a new one.
May 19, 2011 | Cobra Radio Communications
I jus was wondering, can the cb radio and the handheld radio transmit on the same channel? Im a security officer and im interested in purchase a cb radio so we can use it at work but i dont know if its...
CB radios and hand-held CB radios can operate on the same channel and be in contact with each other. Other hand-held radios do not operate on the same frequencies and even though they may have channel numbers the channels have different frequencies and will not operate to CB radios.
Oct 29, 2010 | Cobra 150 GTL DX Base CB Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I need to wire a sadelta es 880 echo chamber to my cobra 25 LTD ST MOBILE . if i have locator grove on plug upwards . ty for any help you can give
First of all, if you will look closely at the end of the mike plug, you will see numbers 1-4. 1- is shield, 2- is audio,white, 3- is transmit-red, 4-is receive,-black,.....hope this was helpful...
Apr 25, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
I can't xmit or receive on CB channels: Wx channels come in OK. I had a bad WalMart Special mobile antenna which shorted out because of corrosion. Now have a Diesel 15 inch mobile with tunable SWR tip....
If try another mic and see if problem is still
there then you have half of the problem,the
TX an RX all go through the mic if mic good
you will have to go inside of the unit.
Good Luck
Sep 10, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
When i click the mic i get no transmit
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Sep 08, 2009 | Cobra 29 LTD CB Radio
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Tom
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
Cobra 18 Wx St Ii Mobile Cb Radio Logo
271 people viewed this question
Top Cobra Boating Experts
RFburns
Level 1 Expert
Are you a Cobra Boating Expert? Answer questions, earn points and help others
