Question about Dell Latitude C400 Notebook
Where is my memory compartment for my dell latitude c 400
Where do i install more ram for my dell latitude c 400
    Scholar:
  • 135 Answers
Full instructions can be found at:
http://www.elhvb.com/mobokive/edwin/laptops/Dell/LATITUDE/C400/C400.PDF
It's really quite easy so don't worry about it.
Posted on Feb 18, 2009
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
Where dom i insert new memmory in a dell latitude d820 computer?
1. Remove the keyboard bezel with a flathead screwdriver.
2. Remove three screws securing the keyboard
3. Unplug the keyboard cable from the motherboard and remove the keyboard. The internal RAM (memory) slot is located under the keyboard, right above the touch pad buttons.
-How to remove keyboard ( with pictures ) -
http://blogs.microsoft.co.il/blogs/tamir/archive/2007/11/16/diy-how-to-replace-your-dell-latitude-d820-keyboard-for-only-13-99.aspx
Aug 21, 2011 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
WHAT KIND OF RAM DOES A DELL LATITUDE D600?
That would probably be DDR-333 (PC2700) Notebook Memory. I believe a DDR-400 wil also work since it should be backwards compatible.
You should be able to order Dell parts online using this link
http://search.dell.com/results.aspx?c=us&l=en&s=bsd&cat=prod&cs=04&k=latitude+d600+memory&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=tab
You will need to register with the Dell Online shop first though :)
BD
Sep 02, 2010 | Dell Latitude D600 Notebook
Latitude D600 PC Notebook: Installed new RAM 1G on Dell Lat600,Now CPU is run...
It is not the memory causing the issue. You either have a clogged fan and heat sink or a bad fan. This will solve most heat issues with the laptop.http://www.diefer.de/i8kfan/faq.html
Install this software and put the fan on manual high. That should help a lot if the fan is still working.
May 18, 2010 | Dell Latitude D600 Notebook
Has 1Gb Ram installed. Bios not recognizing dimm
was it new ram you bought or was it out of some other machine because it might be a caes of bad ram. try your old ram in the laptop and see if it boots up if so then get your ram chaged.
Mar 14, 2010 | Dell Latitude C840 Notebook
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
Add ram memory to a Dell Latitude CS Series
go to crucial.com and use there online tool..that will help u!!
Nov 16, 2008 | Dell Latitude CS Notebook
Dell Latitude C400 Notebook Logo
154 people viewed this question
Alun Cox
