Question about Solar X-10 Home Pro Dimmer Switch Hpd3-i Ivory W/o Wallplat
Bedroom light not wired correctly...need help. new installation with supply power 14-2 wire (blk, wht and grd) in box with 14-2 wire (blk, wht and grd) going to the light. seems simple but dimmer switch won't work or breaker trips or arc happens at switch. please help with connections.
  • Anonymous Mar 13, 2014
    I need to take power from a 3 way switch to power a 2 way switch in the same box. Can I do this, and how, please.
  • 547 Answers
White wire cut in half attach white wire to switch both screws attach ground to box blach wire just runs through
Posted on Feb 18, 2009
Get sound on radio install.
Your 2004 Vibe may have been equipped with a radio or a radio and separate amplifier. The BLU/WHT wire supplies +12 V to the radio. The radio ground wire is BRN. A GRY wire powers dial illumination. The BLK/WHT wire you mention is either the antenna input or a sensitivity control input to the amplifier. There also may have been a WHT mute control wire connected to the amplifier. The Vibe has an antenna amplifier which needs +12 v. The aftermarket radio should have separate LF, RF, LR, and RR outputs to connect to the corresponding speakers or amplifier inputs.
Sep 13, 2016 | Cars & Trucks
2004 f350 fasher diogram
Can't supply a diagram but I can tell you that 15A fuse 27 in the central junction box (CJB) applies power via a LT BLU/PNK wire to terminal 2 (the coil) of the indicator flasher relay in auxiliary relay box 1. 20A fuse 18 in the CJB applies power via a LTGRN/RED wire to the brake pedal position switch and terminal 3 (the relay arm). Terminal 5 of the relay connects the relay coil to ground (BLK wire). Terminal 1 of the relay supplies power via the LT BLU wire to the turn signals when the relay is closed. Terminal 4 supplies power via the WHT/RED wire to the hazard light circuit when the relay is open.
Oct 31, 2012 | Cars & Trucks
I have a mazda mvp 1993 v6 and i need what each coler and what eachean for a radio help me
If this is a new radio you are installing, these are the existing Mazda connections:
In joint box: BLU/BLK wire from 15A CIGAR fuse (accy/run power); BLU/RED wire from 15A ROOM fuse (always hot power).
LF speaker: RED and RED/BLK; RF speaker: RED/YEL and ORG/BLU (or RED/WHT); LR speaker: BRN and BRN/WHT, RR speaker: BRN/YEL and BRN/BLK; L door woofer: GRN/BLK and GRN/ORG; R door woofer: GRN (or GRN/WHT and GRN/RED
Sep 27, 2012 | Dual New Xr4115 Mechless Digital Media...
2000 Celica GT AC and dashboard lights & gauges out suddenly (Together)
Here's how it should work: Power for the instrument panel comes from the 7.5A ECU-B fuse in the instrument panel junction box (I/PJB). A WHT/BLK wire from the instrument panel is grounded in that box. The I/PJB also contains a 5A WARNING fuse which is connected to the instrument panel by a RED/YEL wire. The 5A BKUP LAMP fuse supplies power on a RED/BLU wire to the vehicle speed sensor (combination meter) and a LT GRN wire from sensor is connected to the instrument panel. In addition, a LT GRN/RED wire from the instrument panel connects to the ECM. The YEL/GRN and RED/BLU wires from the instrument panel connect to the body ECU. There are three ground wires: two WHT/BLK and one BRN
Sep 20, 2012 | 2000 Toyota Celica
I am installing a 240v heater in my downstairs bathroom. The heater schematic has a single BLACK 240v live input wire and a WHITE 240v neutral output wire, plus a yellow/green stripe ground wire. I have...
you dont need all that wht is 120vt blk is 120vt thats your 240 their is no neatral on 240 volt ont a 120 volt circuit it sounds like it is wired correctly you may have a wire not getting good conection
Sep 18, 2010 | Heating & Cooling
Stereo wiring for a 91 honda accord
1. red/blk ---------lighting switch
2.wht/yel-----------to fuse No.24 (7.5A) under hood relay box
3. yel/red---------- to fuse No. 11 (10A) Dash fuse box
4.brn/blk ----------- (--) R front speaker
red/grn ----------(+)
6. brn/blk-------------(--) L front
blu/grn
7.brn/wht -----------(--) R. Rear speaker
red/ywl-------------(+)
8. gry/wht----------(--) L..Rear
blu/yel ----------(+)
9.BLK----------------- to the ground.
Apr 05, 2010 | 1991 Honda Accord
Need colour codes for stereo wiring for 2000 hyundai accent
ANT org/wht, LR spkr brn/blk, LF spk blu/blk, RF spk blk/wht, RR spk grn/blk, ILL blk/wht, ACC gry/wht, GRND blk, LF spk brn/wht, RF spk brn, RR spk grn/wht, ILL grn/wht, MEM power org/blk.
Dec 26, 2009 | 2000 Hyundai Accent
I am trying to find out the wiring colors and what they are. I am trying to install a cd player in my 94 honda accord but ca't figure out the wire colors to be able to hook up correctly. Need Help!!
yel/red battery(always hot),wht/blue hot w/ignition,red/blk hot w/lighting switch,blk ground,red/grn rt ft +,brn/blk rt ft -,blue/grn lt ft +,gry/blk lt ft -, blue/yel rt rr +,gry/whte rt rr -,red/yel lt rr +, brn/whte lt rr -
Oct 16, 2009 | Honda Accord Cars & Trucks
Need help with 2004 Hyundai Santa Fe Audio Wiring
Sounds like you need a light tester. I would guess that at least 8 of the wires are speaker + & - the others will be Main power and earth Possibly electric ariel, Memory store and a wire for the anti theft circuit. Assuming the stereo is factory. Any Audio shop can perform a test to clarify the purpose of the wires Wouldnt worry about the blank its probably a position for a newer or different model to yours. Steve in the UK
May 13, 2009 | 2004 Hyundai Santa Fe
Ceiling Fan wires
you don't have the necessary wires. you need to run a 3-wire cable (wht, blk, red, grd) between fan+switch. then post bac for instructions...
Dec 12, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Solar X-10 Home Pro Dimmer Switch Hpd3-i Ivory W/o Wallplat Logo
144 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
