Question about HP Office Equipment & Supplies
C00f0401 error code power on power off
Have tried power on and off
Have tried both fixes suggersted - hold down #5 or #6 keys also removal and replacement of back plate still does not work.
Error code of my printer c00f0401
Posted on Jan 08, 2010
Why do i have a error message c00f0401
HP OfficeJet V40 All-In-One InkJet Printer Error c00f0401 ...
www.fixya.com > ... > HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer, error c00f0401 related issues. ... ...errorC00F0401 This error message can occur if the all-in-one has been stored ...
Oct 08, 2015 | HP OfficeJet V40 All-In-One InkJet Printer
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
Error sc543 sp c320dn
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Feb 17, 2012 | Ricoh SP C320DN AllInOne Laser Printer
Error ba000005 or c00f0401 come up on display. can
my printer is an hp but not the model. i was having the same error though. i unplugged the power from the back for 20 seconds,held the power button while plugging it back in, then held the # and 6 while turning it back on and that fixed it
Nov 23, 2010 | HP PSC 1610 All-In-One InkJet Printer
How do I fix error SC552 on Ricoh 2238C?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Error on the display -
I had the exact same issue with one of these printers. 83C00020 on the display with a blue background. printer will not power off.
Try this - Press and hold the OK button then press the power button to reset the printer .
I did this and it powerd on ok and is now working fine.
Apr 18, 2008 | HP Photosmart 2575 All-In-One InkJet...
Officejetv40
Turn the printer off
Hold down # and 6 while turning it on
Keep holding it down until it finishes turning on.
If that doesn't work then do the same thing using # and 5.
Feb 13, 2008 | HP OfficeJet V40xi InkJet Printer
Error c00f0401
Jan 02, 2008 | HP OfficeJet V40xi InkJet Printer
C00f0401 error code
I have a solution that works.
But first the background: I have an older model HP G85 printer that's a real workhorse and I love it but when I lost power that c00f0401 code came on and I couldn't clear it. So I called HP support and found them USELESS. A search of the Internet tells you to hit the #6 keys to clear it. Some say hit #9 to clear it and others say to hit #5 keys and still others tell you to disconnect the 'self-feeder' tray cable. I eventually cleared it by hitting the #9 key while simultaneously pressing the ON button. I did that about 50 times then it cleared itself and worked fine for a year. However last week I again lost power and when the power came back on again I couldn't clear it no matter how many times I tried.
SO HERE'S MY LATEST CURE and it worked several times in a row--so I think it will always work in the future.
1. Turn printer off
2. With your left hand hond down simultaneously the 5, 6, 9, and # keys an rhytmically press those keys up and down, up and down, (at the rate of about 3 times a second). AND AT THE SAME TIME: Use a finger from your right hand and press the on/off button rhytmically (at the rate of about 3 times a second). Eventually the INITILIZING light will stay light---then take all your fingers off all keys.
3. After waiting a short time (a minute or son) the computer initializes itself and it works fine.
Anyway, it worked for me each time I tried it. I hope it works for you.
Dr. Campbell
Computer Science Dept.
Dec 31, 2007 | HP OfficeJet V40xi InkJet Printer
348 people viewed this question
Seeker5211
Seeker5211
