Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Vaccum shuts off when I go to upright position. I checked the hose and also lower attachment and not clogged.
  • 2 more comments
  • d_chouinard Feb 18, 2009
    yes it is.
    will try that right now ...thanks man and will post the result
    it worked = thanks Mike227
  • Anonymous Mar 06, 2009
    Same problem and same solution.
  • 135 Answers
Is the motor running hot?
Posted on Feb 18, 2009
  • My reply is Feb 18, 2009
    Suggest you remove ALL accessible filters, hand wash them several times in a mild detergent solution (only takes about 10 minutes), squeeze out excess water and be sure they are THOROUGHLY dry before re-fitting.
    You're welcome. PLEASE be sure the filters are properly dry though or your vacuum may **** moisture into the motor. ......... Not good !!!!
My Hoover wind tunnel keeps overheating and the red I dictator is on. I have cleaned all filters and checked for clogs....could the motor have dust in it? How do I check?
Okay. I read these posts and decided to take the advice of checking the hose.
I had cleaned all filters, checked all hose (as-is) and did belt checks, etc.
The indicator was always showing red and it would shut down after about 5 minutes.
It ended up being a clog that I discovered after taking the hose completely off and seeing a clump right where the hose detaches. I began swinging the hose round and round and sure enough, more cat hair clumpls shot out. Big clumps.
So, you literally need to check every inch of hose to find the culprit.
After that, my indicator stayed green and it works like a charm.
Best wishes, Mike D
Dec 03, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
No suctions except when using hose
There is probably a clog between where the hose and brush. If there are any removable flexible sections, pop them off and have a look. If you have access to an air compressor that is a very quick and easy way to blow the clog out in reverse flow path. If you do blow it out I recommend doing this outdoors as it makes a mess. If you do not have air then you need to find a ridgid flexible rod of some sort to push the clog or hook it and pull it out a little at a time.
Jul 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
When vaccuming with the hose it has a high pitch whistleing when using attachments and does not ****
try taking the hoses off, first. Check and see if their is a clog. Ususally if their is one, its in the unit itself and not the hoses. TO get at the clog, try using a metal cloths hanger. Its the only thing i have found around the house that works at getting at clogs.
Oct 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts...
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Dec 21, 2008 | Kenmore 31913 Progressive Direct Drive...
Decreased suction at hose end
Yes, the "door" on the angle hose might not closing properly when the vacuum is in the upright position (if you look at the vacuum from the back, this hose connects the back to the bottom of the vacuum and it has a "door" at the very bottom end that is supposed to block suction to the lower part of the vacuum while upright) Check for a build up of linty stuff in the corner. The best way to access this is to remove the two screws on the clamp found at the top of the hose, (freeing the hose on top only), straighten hose so you can see inside to the end, and watch inside as you press the upright release lever. (awkward, but worth the effort) You should be able to see the door move -it should be completely open when the vacuum is not locked upright, and should be completely closed when upright. Remove anything that might be preventing it from closing - I used a flathead screwdriver. Hope this helps someone!!!!
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Bissel upright vaccum model 6594
Did you check the inlet hose down by the brush roll, it may be clogged there. Your system says that that must be a clog. Did you drop something like a big marble down thru the hose and have go all the way thru?
Oct 27, 2007 | Bissell 9200 Upright Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
133 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
