Question about Sharp AR 201 Copier
DISPLAY ALTERNATES "L" THAN "6"
Sharp AR 201 Copier
    President:
  • Sharp Master
  • 990 Answers
Hello sir; this machine have a laser unit problem, replace it !
Posted on Feb 18, 2009
Is the Sharp AR 201 compatible with Windows 8
No it's not. Your best bet is to try an HP driver.
If you're ready for a new machine I can give you a quote!
Skelton Business Equipment Houston Copiers
Jun 08, 2014 | Sharp AR 201 Copier
Developer signal
On a Sharp AR-201, the developer light comes on when 50,000 pages have been made since the technician (or factory,) last changed the developer substance and reset the counter. A tech should come out with a Preventative Maintenance kit because training is needed to remove the developer substance safely as well as to clean the optics, interior and inspect the fixing unit, drum and cleaning blade and vacuum out the copier. You should call for service and tell them the developer light is on so they know to bring a kit. And yes... I am factory trained on this model. Retired now.
Nov 24, 2012 | Sharp AR 201 Copier
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
SHARP AR 201 - ERROR CODE H4
# * C * den start batan the copier will re-start
Oct 07, 2010 | Sharp AR 201 Copier
Ar-160 display says "check panel" no more codes or functionality
tis problem is some of panel button is short i mean it is lock please open your machine panel board and service it . then solve your problem
Aug 02, 2009 | Sharp AR 201 Copier
Incomplete copy
the paper is set to 8.5-11 and you are running letter r paper u must set the copier tray to the proper size
Mar 03, 2009 | Sharp AR 201 Copier
Problem with copier SHARP AR-206 display
what is the problem with the display ? is it out ? or showing an error ?
Apr 05, 2008 | Sharp AR-207 Copier
AR-201 shows "check panel"
plese write the error codes coming on the display
Sep 23, 2007 | Sharp AR 201 Copier
H and 3 Reading
This is a fuser (heating section) trouble code. It means that a higher than normal temperature was detected in the fuser. To reset you must press the following keys in order. Press the clear key, then interrupt, then the number 0 then interrupt. The display will change and you then enter the numbers 1 and 4 then press "print" the machine will then restart the warm up sequence. If the code reappears, your thermistor is bad and must be replaced. Only a technician can do this. Let me know if this helps. Aloha Bill Monroe
Sep 06, 2007 | Sharp AR 201 Copier
Sharp ar 201copier not working
L6 means that the polygon mirror is locked up. I have repairedthis many times in HP laser printers and is is relatively easy. The top cover needs to be removed and laser scanner opened. Then remove and clean the mirror asm. May have to replace the scanner asm. This will be expensive.
Aug 01, 2007 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
